Ok so no progress over many months lol, mostly due to getting distracted with other mini and house. Anyhow I found a new idler gear at castle coombe for £5 and a flywheel housing for £10, plus minisport had gearbox bearing kits for £55 so it inspired me to crack on.
Old gearbox looked like it could have had a crack in it, and I have another in poor order but the case is good so I'm making one good one out of the two. Thanks to guessworks for his video's, and Oltonlad on here for the stripping guide.
This is the gearbox (Ipad cameras rubbish) before work started. After a clean with oven cleaner (gears not case) the gears are really good, and the baulk rings are nice and tight.
The only problem with the gears is the laygear which has a damaged tooth. Looking at what people say on here it wouldn't probably be ok, but the one from the other gearbox is perfect so Ill use that one.
Once stripped out I gave the case a good clean in water and degreaser as to not gack up my glass bead.
Before blast
Afterwards - Not perfect, but pretty good considering what it looked like. Bearings turned up today so Ill give the case a steam clean at work to remove any last bits and stray media, remove the laygear from the 2nd gearbox and start the rebuild.
Edited by hustybusty, 04 February 2014 - 10:01 PM.
