Mot Tomorrow Help!
17 replies to this topic
#1 Mr.P
Mr.P
  • 145 posts
Posted 17 June 2013 - 07:35 PM
Evening,
After sone quick advice
1970 Clubman Estate - brake test switch fitted - doesn't work.
Does it need one for the MOT? Would it have had one from new?
If it's fitted does it have to work?
For some reason, if you join the wires at the engine side, as if there was no fluid, then the switch only lights up if you press it - shouldn't it stay on?
Peter
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 June 2013 - 07:37 PM
If fitted it should work my 1980 mk4 has one and when pressed lights up
#3 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 17 June 2013 - 07:58 PM
Take it out?
#4 samsfern
samsfern
  • 5,243 posts
Evening,
Peter
Just leave the wires joined up for the mot, so it works if the tester bothers trying it :thumbsup: the switch is suppose to light up if you press it, thats to check the bulb works :lol:
#5 ianclark1275
ianclark1275
  • 56 posts
  • Local Club: Minicross drivers association
Posted 17 June 2013 - 08:42 PM
i just changed it prior to MOT, and light switch, £13 Each   gulp.
IC
#6 ianclark1275
ianclark1275
  • 56 posts
Posted 17 June 2013 - 08:44 PM
you can pull the front of the switch off and unscrew the bulb and change for a bulb from a spare switch if you have one but be careful, i ruined mine.
#7 Mr.P
Mr.P
  • 145 posts
Posted 17 June 2013 - 09:10 PM
thanks all - fixed now so it works - but in the process knackered the fog light somehow - doh
#8 Jase
Jase
  • 1,166 posts
Posted 17 June 2013 - 09:23 PM
you don't need a fog light on a 1970 car for the mot
#9 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 17 June 2013 - 09:35 PM
But if it's got one fitted it has to work.
#10 Mr.P
Mr.P
  • 145 posts
Posted 17 June 2013 - 09:41 PM
well that's one thing that might be removed tomorrow morning !!!
#11 Jase
Jase
  • 1,166 posts
Posted 17 June 2013 - 09:50 PM
That's an easy fix :)
#12 adampat84
adampat84
  • 288 posts
  • Local Club: Dorset Mini Club
Posted 18 June 2013 - 11:43 AM
Pass?? Fail???
The suspense in killing me!! :geek:
#13 Mr.P
Mr.P
  • 145 posts
Posted 18 June 2013 - 04:02 PM
Pass?? Fail???
Sat waiting now for it to be done now...
Half expect a long list
#14 Chris1992
Chris1992
  • 2,022 posts
Posted 18 June 2013 - 04:08 PM
good luck mate!  ;-)
#15 Mr.P
Mr.P
  • 145 posts
Posted 18 June 2013 - 05:24 PM
well.........all minor stuff :) :)
I was half expecting him to say which ever numpty did these brakes/suspension/gaiters needs shooting - but thankfully they are all fine.
It would seem that last night when I fixed the brake test light not only did I knacker the fog light, but the horn as well - are they on the same fuse?
1. Horn
2. headlight aim
3. beam pattern
4. blue full beam light on dash.
Headlights were next on the list anyway - just was hoping to wait to next pay day - Cibies it is then.
and advisory
1. slight play in steering
2. front wheel bearing
So retest 8:30am saturday morning, then post office for tax, afternoon polishing then Blackpool Run on Sunday. :)
