What Would My Budget Get Me (Van)?
8 replies to this topic
#1 craigr91
craigr91
  • 429 posts
  • Local Club: nwminiclub
Posted 17 June 2013 - 07:35 PM
Am after a van and seen a few but wondering what van in condition etc I would get with 3500-4000?
There's a local one at 3995 ovno, looks ok not show condition, not really looked proper as I want to know what I should expect
Thanks, Craig
#2 craigr91
craigr91
  • 429 posts
Posted 17 June 2013 - 07:40 PM
Anybody? Am I looking at something that will scrape through mot or a decent ish van showing signs of surface rust?
Cheera
Edited by craigr91, 19 June 2013 - 10:01 PM.
#3 craigr91
craigr91
  • 429 posts
Posted 19 June 2013 - 10:02 PM
Bump - gonna try get down to view but unsure when as really busy at wirk
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 19 June 2013 - 10:19 PM
Van's really do seem to fetch a premium these days, so you're unlikely to get great one for around the £3.5k - £4k mark. In my experience mint/show condition vans often go for two, to three times, the amount that am equivalent roundnose saloon model would. So if you've seen a reasonable example for around £4k then it's probably a pretty good buy.
Also be aware that being one of the rarer and more desirable derivatives, vans are one of the most frequently stolen types of classic mini. So if you get one, then make sure you invest in some decent security for it and be very careful about where you leave it too.
#5 craigr91
craigr91
  • 429 posts
Posted 19 June 2013 - 10:34 PM
That's one of the first things ill be doing font worry about that, any specific areas on a van that I should be looking for other than the normal saloon areas?
#6 ChrisCityE
ChrisCityE
  • 418 posts
Posted 19 June 2013 - 11:15 PM
Check out the back out thoroughly, Estates and Vans rust badly on the rear sides by the arches. It's not uncommon for the rear pillars to be completely detached from the floor. Check my pics for the usual rust spots.
#7 craigr91
craigr91
  • 429 posts
Posted 20 June 2013 - 06:31 AM
Thank you, just read your build and it has showed a lot of major rust spots :£
Thanks again
#8 ChrisCityE
ChrisCityE
  • 418 posts
Posted 20 June 2013 - 08:39 AM
No problem, at least you can get the majority of the panels for a Van should you have a problem.
#9 craigr91
craigr91
  • 429 posts
Posted 20 June 2013 - 09:12 AM
That's one reason I don't mind it being tatty, ima want to learn to weld anyhow :) weld, etch prime, rattle can paint and back on the move haha :)
