I have a set of 12" steelies that fits over 8.4 brakes, I've been told they might be off of an Imp.
10" Look A Like 12" Steel Reverse Rims
#16
Posted 19 June 2013 - 07:49 AM
#17
Posted 19 June 2013 - 08:06 AM
It does say that those can't be fitted over 12" brakes :/
#18
Posted 19 June 2013 - 08:11 AM
Photo here:
Nice! are you running them with spacers on the front at all? iv also got group two wides. those wheels really suit your mini
#19
Posted 19 June 2013 - 11:41 AM
The closest you can get to a 10" reverse rim that will clear a set of 8.4's without arches is a set of stock mini12" steels with some chrome hubcaps like Miniworld are running on 'Sheldon'
All 12" steels clear 8.4" brakes, that is the stock size for post 85 minis fitted with them.
Photo here:
They have a built in spacer so it sits clear of the callipers
#20
Posted 19 June 2013 - 11:42 AM
#21
Posted 19 June 2013 - 11:44 AM
I'm not using arches so can't be wide
#22
Posted 19 June 2013 - 11:46 AM
They are 10"
nope, they are stock 12" rims
#23
Posted 19 June 2013 - 11:48 AM
#24
Posted 19 June 2013 - 04:55 PM
All 12" steels clear 8.4" brakes, that is the stock size for post 85 minis fitted with them.I have a set of 12" steelies that fits over 8.4 brakes, I've been told they might be off of an Imp.
Right, I meant to say hubcaps off an imp.
exactly like the picture you posted. I had to do a double take to see if that was my mini lol.
Edited by minimarco, 19 June 2013 - 04:56 PM.
#25
Posted 19 June 2013 - 05:30 PM
#26
Posted 19 June 2013 - 07:07 PM
not sure if they will have the same look
#27
Posted 20 June 2013 - 04:56 AM
Use a cheap steelie and paint in the colour you want and then see if you like it if not dont get them that's what I did
#28
Posted 20 June 2013 - 05:19 AM
dont want to use standard 12's
#29
Posted 20 June 2013 - 06:47 AM
There are no 12" steels other than the stock mini ones that will fit without arches.
#30
Posted 20 June 2013 - 06:49 AM
Ah, so that's were they got them from, I thought they might have got them from Japan as I've seen a few over there running 12's with hubcaps.
