Huddersfield Spares Coil Conversion
7 replies to this topic
#1 KSTANDSTEVE
KSTANDSTEVE
  • 439 posts
Posted 19 June 2013 - 01:00 PM
As I am rebuilding my rear subframe was considering ditching the rubber cones and going for the Coil spring conversion supplied by Huddersfield Spares.
Would go for the standard sping setting rather than hard.
Anyone any experience of these?
Steve
#2 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 19 June 2013 - 01:12 PM
I've got the fast road ones fitted and they are great, although if you carry people in the back you need to wind the suspension up quite high.
#3 KSTANDSTEVE
KSTANDSTEVE
  • 439 posts
Posted 19 June 2013 - 02:40 PM
Higher than standard ride height?
#4 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 19 June 2013 - 02:53 PM
I did a fair bit of research on the spring conversion before I went for the Minitastic ones
http://www.minitastic.co.uk/home1.htm
Haven't had them fitted long but so far they are great, I fitted Gaz shocks and heavy duty tie rods at the same time and its all good
#5 Cooperman
  • 23,313 posts
Posted 19 June 2013 - 06:16 PM
It is impossible to beat the original rubber spring cones for all-round performance and ride. They are a true 'rising rate' spring with the correct rate-curve for the Mini.
#6 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 19 June 2013 - 06:34 PM
For optimum performance, yes. But few drivers are looking for the ultimate performance in their daily drives.
This topic springs up (see what I did there) about once a month and there's always the same division of opinion often unobjective where people make statements about the unsuitability of spring conversions without any first hand experience of the product. Compared to many people who do use these conversions on their daily use car to great effect both with and without passengers and varying loads with no ill consequence.
If you're not looking for best performance handling from your mini but something that is a little more compliant and comfortable to drive on our pot hole laden highways and bi ways, coil conversions are a great option.
They do what they aim to very well, which is give a far improved ride and better road use characteristics equal or above fresh rubber and far beyond worn, with a much greater functional lifespan. But they won't offer the performance of a rubber donut.
#7 MR J
MR J
  • 416 posts
Posted 19 June 2013 - 09:01 PM
Couldn't agree more, i wouldn't say mine handles better but it's a lot more comfortable to drive.
#8 MR J
MR J
  • 416 posts
Yes.
