Oh Gowd Found Another One!
18 replies to this topic
#1 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 19 June 2013 - 04:46 PM
a hole inside my rear wheel arch.., is it a hard/expensive area for a pro to fix?
along with
two front wings
two a panels
scuttle
front panel
drivers floor panel
pass door step
guttering
bulkhead repairs
im wondering if its worth it on an 89 car,as i need a pro to weld it so you can guess the price!
#2 scaffers
scaffers
  • 476 posts
Posted 19 June 2013 - 04:50 PM
Why don't you want to do it yourself?
#3 leroy26
leroy26
  • 2,239 posts
Posted 19 June 2013 - 04:53 PM
would you let frank spencer loose with a welder.. lol
#4 leroy26
leroy26
  • 2,239 posts
Posted 19 June 2013 - 06:03 PM
should i sell or be brave?... decisons huh!
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 19 June 2013 - 06:04 PM
Give it a go yourself. The arches can be a pain due to the contours but it does depend on where abouts the hole is exactly???
#6 leroy26
leroy26
  • 2,239 posts
Posted 19 June 2013 - 06:07 PM
right at the top near the skin
#7 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 June 2013 - 06:13 PM
Do you mean the quarter panel side?? The big problem i have found with arches is its ok to patch in a lot of places but when it starts to go close to the flanges then you may need to think about a half arch replacement. By the sounds of it you have a lot to do anyway so one extra job won't be too harsh.
Shame you are too far away or i would have sorted it for you.
#8 leroy26
leroy26
  • 2,239 posts
Posted 19 June 2013 - 06:18 PM
thanks dude! woulda bin good! how much is a half arch, yes meant quarter panel
#9 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 June 2013 - 06:20 PM
Ok this is the one you need
£31.60.
#10 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 19 June 2013 - 06:25 PM
I have just fitted one of these and will do the other soon. The hardest part is getting the old one off without damaging the surrounding panels.
#11 leroy26
leroy26
  • 2,239 posts
Posted 19 June 2013 - 06:27 PM
yep thats the one! unfortunatly i cant weld!
#12 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 June 2013 - 06:28 PM
Done both and yep its careful drilling of spot welds time to be honest. The one W.O.E has done is a pain as the boot bracket to seat belt mount is there as well so picking those spot welds up can be tricky.
A bit confused now, is the inner section of the arch or the outer section you have found a hole in??
#13 leroy26
leroy26
  • 2,239 posts
Posted 19 June 2013 - 06:32 PM
the bit where all the mud clings to under the arch!, i was cleaning under there and it suddenly went tap tap crunch!
#14 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 19 June 2013 - 07:20 PM
For fun here's a pic of the one I have not done yet.
  • Attached File  arch.jpg   97.08K   18 downloads
#15 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 19 June 2013 - 07:29 PM
Yep that's properly rusted through. Hopefully the rust has not travelled up the bulkhead???
