Mini Magazine July 2013 Cam Timing Article
6 replies to this topic
#1 Pete649
Pete649
  • 375 posts
Posted 19 June 2013 - 06:06 PM
Has anyone seen Keith Calver's article on cam timing in the July '13 issue of Mini Mag? I had not appreciated it could be done at the valve with the head fitted instead of at the pushrod without the head. Makes perfect sense.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2013 - 07:32 PM
Good article and very indepth and various ways it can/should be done.
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,764 posts
Posted 19 June 2013 - 08:54 PM
Those in the know, don't even use a timing disc, cam timing takes about 2mins to check one you have a true TDC point. Only need to remove the rocker cover. ANd no dial gauges needed. Just feeler blades and a small straight edge.
AC
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2013 - 09:15 PM
Be good for a short write up here and very handy AC if you have a Min or three
#5 jaydee
jaydee
  • 8,565 posts
Posted 19 June 2013 - 10:32 PM
Havent read the article yet, is he talking about the 'equal lift' method?
If so thats a very good way to time in camshafts
#6 Pete649
Pete649
  • 375 posts
Posted 23 June 2013 - 04:48 PM
No, Its about using a DTI to measure full lift at whatever degrees but taking measurements at the valve with the head fitted rather than the pushrod before the head is fitted.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,764 posts
Posted 23 June 2013 - 09:17 PM
Short on time. Not now.
Ac
