Vaccuum Gauge
8 replies to this topic
#1 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 02 May 2006 - 02:31 PM
Hi All,
I have come into posession of a Smiths Vacuum gauge and have two questions;
Firstly, what does it do ! I cant really get my head around why you would want to measure the 'vacuum' at presumably the carb but have seen then on sale as econometers. Is it to do with fuel economy ? or am I getting the wrong end of two completely different sticks !?
Secondly, how do I install it !
Thanks for any assistance
Jimmy
#2 Jammy
Jammy
  • 25,397 posts
Posted 02 May 2006 - 02:35 PM
Yea, your pretty much there. With the A series engines, they suck the fuel from the carb using the vacumn of the engine. Therefore if you can monitor the vacumn you know whether the engine is sucking a lot of fuel or not much.
#3 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 02 May 2006 - 02:37 PM
It shows the manifold vacuum, and gives an indication of how much you've got your right foot down, and how that affects the fuel economy. So if you go by what it tells you, then you won't floor it so much and you'll save a bit on fuel.
It connects to the inlet manifold. Or you can get a spacer with a take off that sits beteen the carb and manifold.
#4 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 02 May 2006 - 02:56 PM
Lol, can I fit it to my gf :D
Thanks guys, makes more sense know but seems a bit pointless ! Will probably put it in the for sale section then !
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 02 May 2006 - 04:24 PM
Vacuum gauges are hardly pointless if you have a car with a carb and/or if you want to monitor your driving.
Once you learn to drive by glancing over periodically at the gauge you will be able to get the most out of your tank of gas. You'll know how best to use the throttle and when to coast.
Vacuum gauges are also an excellent auxiliary gauge to use when tuning. You can play with your carb and timing settings to achieve the maximum steady idle vacuum. The reward for this is better fuel economy.
Lastly, with experience you can use the gauge to monitor the condition of engine components. You need to back up your findings with other test methods, but the vacuum gauge can indicate problems with the valves, rings, and ignition timing.
If the gauge is in good shape and you don't want it, you certainly won't have any problems finding a home for it using eBay. Before you do, check out a couple of these pages:
http://www.classictr...cts/vac/uum.htm
http://www.centurype....com/vacuum.asp
http://www.free-ed.n...p?iNum=01030305
#6 Pooky
Pooky
  • 5,691 posts
Posted 02 May 2006 - 05:17 PM
How do you fit one? Easy? I fancy one now! :D
#7 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 02 May 2006 - 06:28 PM
Thanks DKlawson, now I've seen it think I might keep it ! It looks nice and from those pages will probably certainly prove useful :D
Pooky, it looks pretty easy to fit. Just needs the relevant tube and fitment going to the manifold as above and the bulb wiring in :w00t:
Jimmy
#8 sevretta
sevretta
  • 320 posts
Posted 02 May 2006 - 06:32 PM
You happy with the gauges mate....jimmy
#9 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 02 May 2006 - 06:39 PM
Yes Mate, in really good nick :D Gonna look really good in the dash :w00t: Thanks for leaving the wiring on !
Cant get the clock out though ! lol, the little round nut wont come off the end, need my tap and die set to sort the end of the bolt bit out but I cant find it !
Jimmy
