I know that the best way to tune an 850 is to put it in a skip and buy a 1275, but that's not the point here!
I have a 1964 mk1 Austin Super De-luxe, and I want to build up a second engine (I'm not messing with the original matching number engine!!!) The idea is that this is to be a fun 850 screamer that feels fast, so massive low down torque and drive-ability is actually not what I am looking for.
The spec that I am aiming for is:
12G295 Head - skimmed to bring up C/R ~10:1 - (Vizard says aim for 11:1 if the camshaft is between 250' and 270') + rimflow 3 angle valves
Pressed steel rockers
Twin HS2 carbs (I know a hif38/44 or hs4 might be better, but I want to keep the engine looking vaguely period)
Standard Crank - (wedged/balanced/nitrided/bladed?) delete as appropriate
Lightest flywheel I can get
Block machined for full camshaft bearings + center main strap
I have two camshafts kicking around, is either suitable?
I have a choice of a minisport CA2 camshaft: http://www.minisport..._CAMCA2MK3.html
Or the minispares Evolution001 http://www.minispare...OLUTION001.aspx (my preference)
Duplex timing gear (or maybe even one of these:http://www.minispare...JJ3328RACE.aspx)
Maniflow freeflow exhaust manifold
Rebuilt gearbox with cross-pin diff and S/C drop gears, and will keep the magic wand (I have a remote housing, but I can't really bring myself to cut the shell)
Apart from any comments on the spec, I have three questions:
- Where is best to get the block machined for camshaft bearings and the head machining done (I am in North Wilts)
- Are those the best camshafts? I have seen builds using a 649 in an 850
- What piston / rod / crank combo should I use? Options:
- Standard crank / standard split skirt pistons / standard rods
- Standard crank / solid skirt 850 pistons / standard rods
- Standard crank / solid skirt 948 sprite forged pistons (where to buy?) / 998 rods or 970 Cooper S rods (so I can take less off the top of the block)
- Standard crank - offset ground big ends / 998 pistons (effectively +65) / 998 rods or 970 Cooper S rods (so I can take less off the top of the block)
(although vizard says that +60 pistons in an 850 produces less power than +40)
This looks like it should be fun
