Fixie / Fixed Gear Road Bike
4 replies to this topic
#1 mike.
mike.
  • 6,176 posts
Posted 21 June 2013 - 02:21 PM
For sale is my fixed gear road bike.
This is around 2 years old and has maybe covered 100 miles since purchase, which is nothing on a bike like this.
I bought this when I was at uni, living in the city centre. Its a great bike for getting around on, looks sweet, goes fast with no effort, requires virtually no maintenance and once adjusted to your size, you never need to touch it again apart from keeping the tyres pumped up and chain oiled.
Perfect for commuting.
The frame size is quite large. Ideally suited for somebody around 6 foot tall. However i'm on 5' 8" and I can ride it fine with the seat down slightly from where it is in the photos.
Spec and new parts fitted are detailed below. The only bad points about the bike are numerous small chips on the frame due to the bike being locked against railings and posts. Also the bar tape could do with replacing as it has shifted on the bars and has torn in a couple of places where the bike has brushed along walls etc whilst being locked up.
Only Selling as i'm downsizing my garage and have no room for it!
Asking price is £200. The bike cost £265 new and has had around £150 spent on new parts since. Will also be advertised on ebay, so be quick if you are interested.
Collection only from Manchester. Can be delivered around Manchester for petrol money.
Spec as follows:
Frame: Tig welded high-tensile steel frame with cable guides, allen key bolting seat post clamp and bottle cage points
Forks: Tig welded with straight ovalised blades
Wheels: 700c x 23, 40mm deep section alloy rim, large flange alloy 32 spoke hubs.
Cranks: 165mm alloy with 44T, 5 bolt ring
Bottom bracket: Sealed unit
Weight: 10.5Kg
Since purchase the bike has been upgraded with around £150 of new parts, including:
Tyres: Dutch Perfect No flat - Puncture proof tyres (great road tyres - I got about 5 punctures before buying these and have had none since)
Bars/Stem: Chrome drop bars, polished alloy 110mm Richey road stem
Brake Lever: Diatec Gold Finger, polished alloy. BMX brake level gives good brake power, whilst keeping the bars free of big levers and cables
Pedals: Primo Tenderizer pedals - BMX Pedals, strong heavy duty pedals
Seat: Selle Royal Viper - Gel seat, really comfy on long trips
Rear Cog: Rear cog has been switched to a 16t for better top speed.
#2 petehuws
petehuws
  • 329 posts
Posted 21 June 2013 - 02:55 PM
Looks good, any idea what size Large is cm?  I'm 6'3" and currently ride a XL 62cm Ridley
Edited by petehuws, 21 June 2013 - 02:57 PM.
#3 mike.
mike.
  • 6,176 posts
Posted 21 June 2013 - 03:19 PM
From the top of the seat tube to centre of the bottom bracket it measures 58cm
#4 scaffers
scaffers
  • 476 posts
Posted 22 June 2013 - 06:26 AM
shame your so far.
good luck
#5 mike.
mike.
  • 6,176 posts
Posted 23 June 2013 - 01:34 PM
Now SOLD
