Can Someone Verify My Cr Calculations Please?
3 replies to this topic
#1 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 22 June 2013 - 06:52 PM
Hi all
I received my block back from the machine shop today, with the shiny new pistons fitted to the rods.
Crank has been reground & balanced but I asked them not to skim the block as I wanted to measure & work out the CR ratio and then take it back for skimming, rather than guess and get it wrong.
I don't think the block has ever been touched until my work (it has a "B" stamped in the deck)?
  • 0.040" overbore for 1310
  • Minispares Mega pistons with 6cc dish
  • Looking for 10.5:1CR
Working on Info from other posts (thanks Cooperman) I have the calculation, just would like someone to sense check please.
Cylinder head is 23cc
Pistons are currently 0.050" from deck
Un swept volume if I am correct:
5.125 (+0.040" bore x 0.050" down) + 6cc (piston dish) + 23cc (head) + 4cc (Gasket) + 0.75cc (ring land) = 38.875
Swept volume = 327.5cc
CR  (SV+UV)/UV = 9.42:1
To achieve CR 10.5:1 I need to have .040" taken from the top of the block to give piston to deck height of 0.010"?
If anyone can verify or, point out my obvious error before I send the block back, it would be appreciated.
Thanks in advance
Steve
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 22 June 2013 - 07:21 PM
Thats correct, assuming 0.75cc ring land. Although what cam are you going to run? Are you sure 10.5 is not too high?
AC
Edited by ACDodd, 22 June 2013 - 07:22 PM.
#3 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 22 June 2013 - 07:33 PM
Thanks for the reply AC.
I assumed the 0.75cc ring land as I have no other info to go on than the figures Cooperman had quoted in another post, although to be fair, that was relating to the 21253 pistons.
I have decided (long story) to go with the Kent 286 I purchased some time back and again, had read that around 10.5:1 was the way to go for this.
Very happy (and at the moment have the ability to do so) to run a lower CR if you could offer advice.
Thanks in advance
Steve
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 22 June 2013 - 08:27 PM
10.5:1 is good for this cam, you must use 97Ron min fuel for this.
AC
