want to add a oil temp gauge but no idea where they go on the engine?
all the gauges i have seen have an electrical connection and not an oil feed?
Posted 23 June 2013 - 07:12 PM
Posted 23 June 2013 - 07:42 PM
You can get an adaptor which replaces your sump plug and the temp gauge connects to that to read oil temp
Posted 23 June 2013 - 07:44 PM
so its used with wire connection and not oil?
Posted 23 June 2013 - 07:55 PM
Edited by Dan, 23 June 2013 - 07:55 PM.
Posted 23 June 2013 - 08:15 PM
got any links to the adapter or how to do it?
Posted 23 June 2013 - 09:38 PM
Some MPI's use an oil temp gauge and an electric sender. The sensor is not fed via the ECU so you can use the gauge and sender. I took mine out and replaced it with an oil pressure gauge. I did this a long time ago. Gauge is lost from about 6 house moves since.
Posted 23 June 2013 - 09:49 PM
The MPi block has a specific fitting for the sender though, it isn't present on any earlier blocks.
Posted 24 June 2013 - 11:35 AM
