Head Ache!
10 replies to this topic
#1 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 23 June 2013 - 08:30 PM
I recently put a new head gasket on my 998 A+, nothing special, your bog standard Cooper one.
After fitting it, torquing it down in the correct sequence, I have noticed once it was filled with water, that I have developed a leak at the clutch end, between the head and the gasket, It is very slowly dripping water!
The block is in good condition and so Is the head So I can almost certainly remove damage to the faces as a cause of the water dripping.
Now, the question is, Should I have got new studs and Nuts when replacing the head gasket, They did not look in a bad way but can't be sure on the age of them!
Secondly, when I rebuilt the engine, It had been fitted with a composite head gasket, I know these are generally better than a Cooper one, but I could be wrong.
I have looked at both Mini Spares and Sport, neither sell a composite gasket!
I fully know the only course of action is to remove the head (AGAIN!) and replace the gasket, make sure that everything is clean.
Is it worth using new studs and bolts, For the sake of £30 I think so?
Can any one shine some light on this, or recommend what I should do next?
#2 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 23 June 2013 - 08:36 PM
Composite head gasket for a 998 from Mini Spares:
Part Number: C-AEA647.
http://minispares.co...|Back to search
Head Stud & Nut Kit:
Part Number: C-AHT279
#3 AlexMozza
AlexMozza
  • 1,248 posts
Posted 23 June 2013 - 08:37 PM
Epic, Ill order a set!
Edited by AlexMozza, 23 June 2013 - 08:40 PM.
#4 Noah
Noah
  • 4,136 posts
Posted 23 June 2013 - 08:40 PM
Yep it will work fine :-)
#5 AlexMozza
AlexMozza
  • 1,248 posts
Posted 23 June 2013 - 08:43 PM
The composite gaskets I use on DB2 Astons require the block to be warmed the re-torqued with no water in, to ensure the best results.
I take it for the mini, just refill, torque down, fill with water the warm up and re check?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 June 2013 - 08:47 PM
Not the first person with a copper gasket to experience that prob composite is the way to go, even though some swear by the copper jobbie
#7 AlexMozza
AlexMozza
  • 1,248 posts
Posted 23 June 2013 - 08:50 PM
Yeah, Ive never been a fan of Copper, on my MGA I use composite, On the Racing DB2's I work on they are all composite too, but when I asked at Sumerford Mini they told me that I could only get copper :/
#8 carbon
carbon
  • 2,590 posts
Posted 23 June 2013 - 08:59 PM
I don't think fitting new studs and nuts will make much difference if the ones you have are able to take the full torque. The A+ studs were pretty decent quality in the first place.
I will probably get laughed off the forum for suggesting this, but if it is a small leak/dribble from a non-critical area then I would be sorely tempted to run it up to temperature and then put in some Radweld... I have used this in the past and it works amazingly well.
#9 AlexMozza
AlexMozza
  • 1,248 posts
Posted 23 June 2013 - 09:29 PM
I was also thinking this, I just dont want to risk creating and other issues!
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 June 2013 - 09:59 PM
I would use a composite gasket rather that try a fix a head to block water leak with rad weld it could lead as you say to other issues like a blocked rad core overheating and the like
#11 BVY
BVY
  • 639 posts
Posted 23 June 2013 - 10:25 PM
I had a similar problem on my last mini. After changing the gasket for a copper one, I had some bubbles coming out where the engine number is. All i did was crack all the nuts off in order and re-torque them and it was fine after that.
