Mini Won't Run Off The Choke
8 replies to this topic
#1 Ro8bieg
Ro8bieg
  • 1,581 posts
  • Local Club: Fylde Mini Club
Posted 23 June 2013 - 09:38 PM
Hi I bought a mini but am having problems with it. It will fire up on choke but as soon as I push the choke in after a few mins it just cuts out. Have noticed blue smoke coming from rear and after inspection found this,
I'm thinking head gasket failure but just wanted to check before I go ahead and change it?
Cheers, Robbie.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 June 2013 - 09:53 PM
Could be from short trips and engine not fully warm to burn off the condensation, do a compression check before taking the head off to confirm to be sure
#3 BVY
BVY
  • 639 posts
Posted 23 June 2013 - 09:54 PM
That is usually a good sign of head gasket!
When it runs with the choke on, does it run smoothly?
The best thing to do it get a compression tester from Halfords for £35. Always handy to have. That will tell you for sure if there's a problem.
At least it's easy to do if you have to change the gasket  :proud:
#4 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 23 June 2013 - 09:58 PM
Engine doesn't run as smoothly as I'd like it to on choke no, back fires more then usual almost sounds like its running on 3 cylinders. When it cuts out it won't start up again for a wile for some reason.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 June 2013 - 10:01 PM
Now you've added a bit more info a compression check will confirm the gasket problem
#6 Ro8bieg
Ro8bieg
  • 1,581 posts
Posted 23 June 2013 - 10:05 PM
Will this one do the job?
http://www.ebay.co.u...=item1e71ed08a3
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 June 2013 - 10:48 PM
Heck thats cheap and included P/P lets us know what its like
#8 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 24 June 2013 - 11:55 AM
You've got to wonder how the hell they do it - I wonder if they will send to Indo......
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 June 2013 - 05:03 PM
If they wont mate I wonder what the cost would be for someone here to buy it and post it out to you ?
