Tapping Noise Whilst Accelerating
Posted 24 June 2013 - 02:29 AM
Posted 24 June 2013 - 09:37 AM
Without hearing the noise, I am shooting in the dark...is it possible something loose on the exhaust? I just fitted a different exhaust on me car this weekend and missing one hanger at the front so there is the tapping noise, but once I accelerate to take off or speed up it goes away.
Posted 24 June 2013 - 10:56 AM
tappets???
Posted 24 June 2013 - 12:54 PM
tappets???
Good call, but can you really hear them from inside the car?
Posted 24 June 2013 - 01:03 PM
A knock could be the engine steady bushes worn
Posted 24 June 2013 - 01:45 PM
not got a clue but if you can then i need to adjust mine ![]()
Posted 24 June 2013 - 02:40 PM
It is virtually impossible to diagnose that fault without seeing and driving the car.
It could be a CV joint, ignition too far advanced or the wrong advance curve at light throttle settings, engine mounting(s), engine steady bushes, inner drive shaft joint, or other things.
To go further would just be guessing really.
Posted 24 June 2013 - 04:54 PM
I'm of the same opinion it could be something as simple as over advanced and what your hear is pinking, have you checked the timing ?
Posted 24 June 2013 - 05:25 PM
tappets???
I can hear mine, well the noisy one. Although I have none of that soundproofing foam stuff at all in the engine bay and cabin.
