My mini wont start in the morning but it will bump start and it will start when it is warm
So last feww days i have been parking it on a hill so i can but start it which is a bit of a nightmare so i was just wondering if anyone can help ? !!
Posted 24 June 2013 - 02:35 PM
Posted 24 June 2013 - 02:57 PM
Bump start ***
Posted 24 June 2013 - 03:18 PM
what have you checked?
fuel
spark
plugs
leads
battery
choke
oil
coolant
fuses
Posted 24 June 2013 - 03:27 PM
Ballast coil on this one?
Posted 24 June 2013 - 03:34 PM
Does it turn over at all - normally or slowly? And are you using the choke properly?
Edited by lewBlew, 24 June 2013 - 03:35 PM.
Posted 24 June 2013 - 03:42 PM
it turns over fine but just wont start :/
Posted 24 June 2013 - 03:46 PM
Posted 24 June 2013 - 04:52 PM
Is the choke working correctly? do you have any air leaks on the carb or manifold joint, sounds weak if it wont start when cold but will when hot.
Posted 24 June 2013 - 05:04 PM
What age and model is your Mini? Check the choke before investigating further!
Posted 30 June 2014 - 12:57 PM
Posted 30 June 2014 - 01:24 PM
Posted 30 June 2014 - 05:06 PM
Posted 30 June 2014 - 07:04 PM
As above, check the earth connections in the boot and in the engine bay. You want clean metal to metal contact between the cable terminals and car body/engine.
Also check other circuits. For example, do the headlights and horn work? Those circuits do not go through the ignition switch. Now turn the key to the run position. Does the red charge warning light come on? How about the turn signals?
Posted 30 July 2014 - 05:51 PM
Posted 30 July 2014 - 05:58 PM
