Dim Dip Problems
6 replies to this topic
#1 Cooper93
Cooper93
  • 135 posts
  • Local Club: P&SMOC
Posted 25 June 2013 - 11:34 AM
Main lights come on with sidelighs, I've done some research and found the dim dip relay under dash, big pink one! Took this off main lights went off, side lights stayed on happy days, put dipped beam...nothing high beam worked tho, why does my dipped beam not work when I remove relay to achieve side light only ?
Edited by Cooper93, 25 June 2013 - 11:36 AM.
#2 Midas Mk1
Midas Mk1
  • 5,793 posts
  • Local Club: S.U.N.M.C
Posted 25 June 2013 - 11:38 AM
I just disconnected the plug to the dim dip resistor near the rad, problem solved :)
#3 Cooper93
Cooper93
  • 135 posts
Posted 25 June 2013 - 11:54 AM
Picture of where its located I had a look for this and couldn't find it?? Mines a 1991 carb cooper if it changes anything
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 25 June 2013 - 11:56 AM
inner wing near the radiator, toward the back near wiper motor...gold looking thing if not painted
#5 Yoda
Yoda
  • 1,958 posts
Posted 25 June 2013 - 12:59 PM
Thats the way to do it!
If you remove the relay, you need to bridge a couple of wires.
Edited by Yoda, 25 June 2013 - 12:59 PM.
#6 Cooper93
Cooper93
  • 135 posts
Posted 25 June 2013 - 03:47 PM
Found it :) had 2 orange wires in it and unplugged it sort of 3pin cylinder and the lights went out after I done it so must be it
#7 tiger99
tiger99
  • 8,584 posts
Posted 26 June 2013 - 09:04 AM
The dim dip relay, if left in circuit, is a frequent cause of headlight failure. Just throw the thing as far away as possible and join the blue-brown and blue-red wires securely, insulating the others.
