Hazard And Indicators Not Working!
1 reply to this topic
#1 BristolDip
BristolDip
    Starting My Mini Up
  • 1 posts
Posted 27 June 2013 - 05:42 PM
Hi all!
Just had a problem with the indicators,
Right indicators work well, relay under the dash works as normal,
Left indicators don't work, relay does work faster symptom like a bulb is off, but none of the left hand side repeaters light on.
When Hazard switch on nothing happens, relay on the engine bay don't work, indicators don't flash.
I've checked the fuse box and all fuses were okay, did check the two line fuses to the hazard relay on the engine bay and one was off so I replaced it with a new one, it did not work so I thought this would have blown off the relay so I replaced it with a new one.
Still nothing happens, after some research they say it could have been the hazard switch so I replaced it with a new one I already had, and still don't work.
Ive checked earths and they are all okay and there is volts on terminals.
I'm getting crazy, this only happens on minis, this just suddenly happens. They were working fine before.
Please anyone could help me out? Did happen to anyone before? Give me some tips please!!
Thanks all
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 June 2013 - 12:19 AM
Its a multimeter job if you have done the normal stuff, fuses, hazard switch replacement. Check the feeds and out on both switches and to confirm the hazard and flasher units are working join both of the wires together , depending which side the indicator switch is on each side should light and with the hazard terminals joined all the indicators should light if the switch is turned on. If you dont get the results listed its time to check the wiring down to the light and the earths.
