Boot Hinges?
Posted 28 June 2013 - 06:15 PM
Thanks chaps
Posted 28 June 2013 - 06:19 PM
I think that they go one way, when i put mine on (secondhand luckly) i just bolted them one then opened boot. It sat up quite abit so i put a little pressure on and snapped one.
I bolted them loose to car and tried them several times till i got them right!!
Posted 28 June 2013 - 06:20 PM
the rear panel's a curve, so they need to be 'bent' opposite to each other incase yours aren't. if you hold them out in front of you and 'hinge' them, you'll work it out... they dont want to be in or out, but parrellel. If the boot WAS flat they would be pointing in
Steve.
Posted 28 June 2013 - 06:21 PM
They will be handed, have a look on the inside of them they should be a mark.
Posted 28 June 2013 - 06:23 PM
