Mini Won't Start After A 2 Year Sleep...
9 replies to this topic
#1 PaulColeman
PaulColeman
  • 712 posts
Posted 28 June 2013 - 08:57 PM
My daughter's 1976 Mini 1000 has been restored over the last couple of years and now it won't start. It was running before we stripped it down and I've not touched the position of the distributor.
I've just replaced the Accuspark module I had fitted because I couldn't get a spark and I've put it back to points, so now it's sparking on all 4 cylinders. I've checked to make sure there's fuel up to the carburettor, which there is as the float bowl is full.
I'm guessing the problem is with the carburettor but I have no idea what to try next. does anybody have any suggestions please?
Thanks, Paul.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 June 2013 - 09:08 PM
Could be stale fuel if its had some in the tank, pour a small amount in the elbow of the carb with the filter off and try and start it then, if it fires and dies then I would look at the carb and see if its blocked up.
#3 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 28 June 2013 - 09:09 PM
Any compression? Piston rings could have stuck in their grooves.
#4 PaulColeman
PaulColeman
  • 712 posts
Posted 28 June 2013 - 09:11 PM
Fuel is fresh as of last week.
The pistons are all free as I only put the head on last week and turned it over to make sure it was free. I haven't done a compression test but with a plug out I can feel the air coming out of the cylinder.
Edit: Just checked the pug leads and two were crossed. It now tries to start but dies. Does that indicate timing?
Cheers, Paul.
Edited by PaulColeman, 28 June 2013 - 09:33 PM.
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 June 2013 - 10:50 PM
Pour a small amount of fuel in the carb elbow and try again
#6 PaulColeman
PaulColeman
  • 712 posts
Posted 29 June 2013 - 08:42 AM
Okay, as soon as I figure out where that is I'll give it a go and report back.
Cheers, Paul.
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 June 2013 - 11:30 AM
The carb elbow is just that bit below the air filter.  Remove the air filter housing cover and tip a thimble of gasoline down the hole in the center as Kernow suggested.  If the engine fires briefly to life and quickly dies this indicates a fuel delivery problem.  After sitting for 2 years it would not be unusual for gum and varnish to plug the hole in the jet.
#8 PaulColeman
PaulColeman
  • 712 posts
Posted 29 June 2013 - 05:32 PM
Well I managed to get it to start... briefly. I turned the distributor around and managed to get it to start. It ran for a minute or two and then I decided to try and set the timing but now I can't get it to start again :(
I didn't know if it was a weak spark so I bought a new coil and set of plug leads but now I can't even see a spark at all grrrrrr
Paul.
#9 madboy
madboy
  • 272 posts
Posted 29 June 2013 - 07:01 PM
Fuel pump ?
#10 PaulColeman
PaulColeman
  • 712 posts
Posted 29 June 2013 - 08:33 PM
I checked the fuel pump and it's fine. The bowl is full so plenty of fuel.
Cheers, Paul.
