quick question - can you use a weber with a turbo?
8 replies to this topic
#1 who_loves_the_mini?
who_loves_the_mini?
  • 1,314 posts
Posted 03 May 2006 - 03:48 PM
I heard a while back somewhere that it was possible to use a weber with a turbo, is this possible and how would you go about doing it?
#2 minimole
minimole
  • 781 posts
Posted 03 May 2006 - 06:15 PM
i am sure dellorto do carbs that a suitable for turbo charging.
#3 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 04 May 2006 - 04:55 AM
A delorto from a lotus esprit turbo is suitable for turboing and fitts right on a webber manifold
#4 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 04 May 2006 - 05:13 PM
If it's a suck through application any carb can be used. If it's for a blow through setup then the carb must be sealed. As already said the Lotus had sealed Dellortos fitted, a Weber can be sealed in the same way. Though i'm not sure if a kit's available or if it's a DIY job ?
Phil. :proud:
#5 minivanman
minivanman
  • 3,454 posts
Posted 05 May 2006 - 08:52 PM
in vizards book theres a pic of a janspeed turbo kit. its a dellorto for a turbo esprit but the system looks like it takes up a lot of room. its in a metro so i dont know if it'd go in a mini.
#6 Brett
Brett
  • 292 posts
  • Local Club: skylineowners.com, turbominis
Posted 05 May 2006 - 09:22 PM
i would have thought so, using the same body mods as you would fitting webbers the plenum cant be much bigger then the webber filter/s
EDIT:actualy scrap that it will go in a mini i have pics......brb
:( :thumbsup:
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 05 May 2006 - 09:32 PM
No, the Janspeed install won't fit straight into the Mini. The downpipe from the Turbo comes out to far against the bulkhead, so you'd need to make a custom job up.
Also the bulkhead box would possibly need to be slightly wider than the usual Weber item, to accomodate the plenum.
Phil. :thumbsup:
Mmmmm .... it won't let me add pictures of my Janspeed motor. Says they're to big, but i've downsized them ? :(
#8 Woody
Woody
    Ring Runner 2005
  • 1,763 posts
Posted 05 May 2006 - 09:53 PM
One way would be to put the whole webber inside the airbox , the presure would be the same inside and out then .
#9 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 06 May 2006 - 01:31 AM
a lá tickford capri if i remember correctly ?
Dave
