New Short Shift Kit - Hard To Engage 2Nd Gear
5 replies to this topic
#1 mattaebersold
mattaebersold
  • 42 posts
Posted 29 June 2013 - 06:10 AM
Hi all, I just installed this KAD short shift kit:
http://www.7ent.com/...kad1013216.html
Everything went smoothly, but when I took the car out for the first time today, I noticed 2nd gear was very hard to engage, it wants to grind and not sink in.
All other gears engage fine.
I am suspecting that it's too short of a throw into 2nd gear, and it can't fully engage.
Notes:
- It will engage about 10% of the time, and only when I'm going very slowly.
- When the car is off, it will clank into each gear ok, seems to be fine
- I am not suspecting any parts in the actual geabox to be bad, since they were OK before starting the shifter install
My main question
Is it possible to adjust the linkage, so that 2nd engages more quickly, so that the shorter throw will fully get into second gear?
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 29 June 2013 - 08:11 AM
The kit has highlighted the fact you have a weak, synchro on second gear, try changing into second at half the speed. This should get you to where the synchro was before you changed the lever.
Ultimately its gearbox rebuild to solve the issue.
AC
#3 racingbob
racingbob
  • 3,061 posts
Posted 29 June 2013 - 08:58 AM
never liked them, whats wrong with ordinary one
ordinary one was fine on my race car
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 June 2013 - 09:06 AM
Yes I'm talking one out of mine and converting back, the lever has poor feel in my opinion and I much prefer the standard change, and in the long run its kinder on the syncros/bulk rings as AC said.
#5 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 29 June 2013 - 09:19 AM
I'll buy it for my auto if you want to flog it.....   ;-)
SOLD :proud:
Edited by KernowCooper, 29 June 2013 - 12:17 PM.
#6 mattaebersold
mattaebersold
  • 42 posts
Posted 29 June 2013 - 04:50 PM
AC: You're talking about a rebuild at the gears correct? Not the rod-change box where the stalk comes out? I am also wondering if the mounts are bad, which would make the whole box rock more than it should, thereby making it harder for the forks to select a gear
