can someone shed some light on a few quiries i have?
im building a 1330 with a MD296 camshaft for racing, what im after is does someone know what poundage spring to run with this cam?
and also what rockers , do i even need roller rockers or are they for the marcho talk down the tavern, what im trying to say is if i dont need rollers which rockers are better to use the wide solid type or the pressed steel, ive read that pressed steel are good and if you run a bead of weld over the top of them they work great, , anyone have a idea?
kerrin
