I want to fit modern fia bucket seats to my mini. They are fibreglass side mounted one's but i don't want to weld in bars across the floor. Has anyone mounted them on sliders, or any other way?
Thanks.
Posted 29 June 2013 - 09:12 PM
Thanks.
Posted 30 June 2013 - 09:53 AM
Edited by keefr22, 30 June 2013 - 09:57 AM.
Posted 30 June 2013 - 11:35 AM
I just made up some brackets (similar to those from tweeks) as i'm tight with my wallet.
But i must agree with Keith....if you are mounting directly to the floor, make sure you reinforce the floor somehow.....and do it properly. I didn't, and even though i've never had any issue with scrutineering and the seats are mega secure, i have recently noticed that the floor is slightly deforming where the mounts are. Over time, i'm sure the mounts will weaken the floor and eventually make a bid for freedom.
Sliders are fine and can be done. I had some Cobra classics on sliders and they mounted to the standard fixings up front but not fixed at the rear so they tipped up. Sold them on as i wanted full back seats.
Proper bars across from sill to exhaust tunnel is the strongest way of doing it, but seeing as you don't want to do that then floor seems the obvious way to go. Just make sure you do it properly and strong....no point cutting corners with your safety.
Posted 12 July 2013 - 01:19 PM
Am I right that the blue books says that (2.2.1) The minimum area of contact between support, shell/chassis and counterplate is 40 sq cm for each mounting point. I am just about to weld mine in only thing is they are not 3mm and don't have a 40 sq cm area ( I have just brought them from a motor sport shop) Is it that the weld in type become part of the chassis and it is the side plates that the rule applies too?
Posted 17 July 2013 - 04:44 PM
That's the way my son & I both read it. And the BlueBook also says this - "2.2.3. The minimum thickness of the supports and counterplates is 3mm for steel and 5mm for light alloy materials". What we can't find anywhere in the book is that the counterplates do actually have to be welded in. In our Ibiza we've only welded those inside the car in & the scrutineer on the recent hillclimb we did was happy with that - we didn't ask him if he'd have been happy if they weren't welded in at all though. We do have 3 mm counterplates on the outside of the shell, just not welded in.
Edited by keefr22, 17 July 2013 - 04:46 PM.
Posted 19 July 2013 - 05:52 AM
Hi Keef, are we saying that if you use the weld in rail type of seat bar, that goes across from sill to tunnel that these two rules don't apply ? As the rule applies to floor mounted seats ? How do I find my local scrutineer ?
Posted 19 July 2013 - 10:45 AM
Posted 20 July 2013 - 07:14 PM
Edited by keefr22, 20 July 2013 - 07:36 PM.
Posted 29 July 2013 - 06:38 PM
Posted 30 July 2013 - 02:09 PM
Interesting, I think I am going to rethink my seat mounting, mine are just bolted through the floor and although I havn't noticed any deforming from track days & sprints, I really want the seat to stay put if anything nasty happens. I am quite tall and to keep the clearance correct between my helmet and the roll cage I really need the seats as low as possible.
Maybe I need bars across but just touching the floor, and then holes in the floor just to get access to bolt the seat to the bars.
Posted 01 August 2013 - 09:59 PM
Posted 02 August 2013 - 08:07 AM
Interesting thread.....and we all need to put our safety first in motorsport as when mini's get it wrong it can be nasty.
DEPS - How tall are you?
I'm 6ft and my seat is positioned so the roll over hoop is behind my seat so shouldn't contact head or helmet. I'm going to check the helmet to roof/bar measurement though as if i ever did roll it i want to be sure i don't end up wearing the roof skin!!!
The big thing for me is to (a) be comfortable and (b) be safe. And i also don't like sitting very low as i prefer to have decent visibility seeing as my car gets used for rallying.
Racing (track stuff) i feel is slightly different as you want the centre of gravity as low as possible and can also get away with not needing soo much visibility seeing as most is gone thanks to a helmet. That, and you are concentrating on whats ahead and not looking around for code boards or dodging cones or sheep in the middle of the night!!!
Posted 02 August 2013 - 10:32 AM
The best bet is to take the seat out, take the subframe off, sit it on the floor behind the crossmember and try it out, that's what I did. You can block it up to see where you want it and then work out if there's room for the bars. Get your head safely below the roll cage and work from there - there are some MSA regs somewhere that say your helmet has to be 1" below your roll cage anyway, which sounds like an absolute minimum for safety.
I had very little choice, I'm only just over 6 foot but it's all in the top half, so with my head comfortably under the roll cage (with helmet) the seat is flat on the floor. Unless you're really tall you should have some choice over how long the seat is, and probably just enough room for the bars.
Posted 23 February 2014 - 04:50 PM
