Radio Interference!
Best Answer petehuws , 02 July 2013 - 12:48 PM
Hi J, for this purpose they're commonly known as a Suppressor, although technicaly a suppressor, capacitor, condensor are the same thing.
They normally would connect to one of the coil + connections and then ground out through it's body to some earthing point, (you can see one installed in the picture below)
There are a few on ebay but this price is a bit optimistic for what is technically just a capacitor.
http://www.ebay.co.u...=item19de7d7b20
Go to the full post
7 replies to this topic
#1 jonnyfawr
jonnyfawr
  • 35 posts
Posted 02 July 2013 - 12:28 PM
Hi, just fitted a retro radio/cassette (with built in MP3 cable...jeez those things are expensive).
Radio works fine, but am gettting some interference.
Haynes says to fit 1-3uf capacitor ...any clues on where to get these, and how to fit?.
Do they need an in-line fuse holder type contraption?
thanks
J
#2 petehuws
petehuws
  • 329 posts
Posted 02 July 2013 - 12:48 PM   Best Answer
Edited by petehuws, 02 July 2013 - 12:49 PM.
#3 jonnyfawr
jonnyfawr
  • 35 posts
Posted 02 July 2013 - 02:12 PM
excellent....cheers !!
#4 TMW.Racing
TMW.Racing
  • 248 posts
Posted 21 October 2014 - 03:01 PM
Sorry to dredge up an old thread but I also have bad radio interference - as I understood it, a condenser was specific to mechanical ignition systems, as I have an electronic system I have not got a condenser fitted. (A) am I correct in not having one fitted, and (B) would fitting one resolve my radio woes without causing any disruption to the ignition?
#5 RooBoonix
RooBoonix
  • 1,225 posts
Posted 21 October 2014 - 03:48 PM
I've got electronic ignition (mine is a 1994 car) and mine has a suppressor fitted :)
#6 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 October 2014 - 03:59 PM
Whoevers Mini that is in the pic above, replace your hose clips to Jubilee branded ones.  The fully open style above are terrible and will fail in no time.
#7 RooBoonix
RooBoonix
  • 1,225 posts
Posted 21 October 2014 - 04:59 PM
And they cut into your pipes :P
#8 TMW.Racing
TMW.Racing
  • 248 posts
Posted 22 October 2014 - 09:19 AM
So will fit a condenser, has anyone had any experience of the signal boosters / amplifiers that are available on the internet? Are they of any use? And if they are, can anyone recommend a good one please!
