Welding Gas - Completely Confused...
25 replies to this topic
#1 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 02 July 2013 - 02:47 PM
Hi all,
I need some welding gas and after a bit of research I am completely confused.
This twin pack of disposable bottles on eBay for £27 mans you get 220 litres, is that correct?
http://www.ebay.co.u...=item257f30086b
However, for £36, Adams Gas have a 9 litre bottle.
https://apps.facebook.com/rentfreegas/
I would also have to buy a regulator for this which aren't cheap.
Surely that is crap value for money and it would be far better to get the first option?
I'm sure there's a very simple answer to this confusion and I am being completely stupid.
Thoughts?
#2 clubman wayne
clubman wayne
  • 66 posts
  • Local Club: robin hood
Posted 02 July 2013 - 02:59 PM
the bottles on ebay will last about 30 min i get a 6kg bottle and it last me ages ive just welded two minis with one 6kg bottle i would imagine it would have taken about 20 of the little bottles i would try your local pub i get mine refiled for £13  hope this helps
#3 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 02 July 2013 - 03:07 PM
I assume that the disposables are referring to the 110 litres of gas that has been compressed into the much smaller volume of liquid inside the cylinders, whereas the Adams gas cylinder is a referring to the size of the cylinder and the amount of compressed gas liquid it holds.
Disposable cylinders are really not very good value for money, the average welding time is only about six minutes per cylinder. The set up costs with refillables (including purchasing a regulator) are much higher but you get a lot more gas for your money. I use Hobbyweld as opposed to Adamsgas, and their website explains the cost of refillables vs disposables quite well. http://www.hobbyweld...7&t=Why Change?
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 02 July 2013 - 03:16 PM
I can't work out the size of the Hobbyweld bottles, but if they're the same size, they appear to be the same price as Adams gas give or take.
The 9 litres refers to the volume of water the cylinder will hold, not the volume of compressed gas!
#5 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 02 July 2013 - 03:19 PM
The licensed trade has much tighter controls on the storage and use of Co2 cylinders than it used to, so getting a cylinder from your local pub tends to be much more difficult than it used to be. Plus argon/co2 mix makes a better sheilding gas for MIG welding, than the pure co2 that you get from pub cylinders anyway.
#6 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 02 July 2013 - 03:34 PM
I don't think you are comparing like with like.  The 9litre bottle is of pure argon (which you don't need).  The Clarke bottles are CO2 with a little argon to reduce splatter.
Bob
#7 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 02 July 2013 - 03:37 PM
They're also 9 litre cylinders, but unless things have changed, Adams gas prices vary from agent to agent. When I compared the two a couple of years ago, it was cheaper to pay for a Hobbyweld cylinder to be delivered to my door, than it was to go and collect one from my local Adams gas supplier.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 02 July 2013 - 03:40 PM
As I live in Kent, I deal with Adams Gas directly, that may be where the difference is!
#9 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 02 July 2013 - 03:42 PM
Bob
I thought he was talking about the Adams gas 9L argon 5% mix cylinder at £36, not the 9L pure argon at £112.60!  :unsure:
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 02 July 2013 - 03:56 PM
Bob
He is talking about the 5% mix, he quoted the price as £36
#11 HarrysMini
HarrysMini
  • 3,352 posts
Posted 02 July 2013 - 04:20 PM
Thanks for the info guys. I did think it looked too good to be true.
I will look into the Hobbyweld products. Also, their regulators are cheaper than what I've seen before. I assume this is the required one http://www.hobbyweld...1 stage 2 gauge
I'd rather spend a bit more to start with but end up saving money, also the regulators that are used with the disposable bottles are utter crap.
#12 rubinio
rubinio
  • 29 posts
Posted 02 July 2013 - 04:31 PM
I got a hobbyweld co2argon mux from my local stockist, cant fault it to be honest.
#13 Old Bob
Old Bob
  • 825 posts
Bob
Sorry but when I looked at that Facebook link it came up with a 9L pure argon quote.  I have looked again twice and each time it has come up with a different price.
It's not only the OP who is confused!
Bob
#14 Carlos W
Carlos W
  • 10,114 posts
Posted 02 July 2013 - 04:39 PM
Thats a CO2 one, I think CO2 bottles are female and argon mix are male (although both pictures are of the same regulator)
#15 HarrysMini
HarrysMini
  • 3,352 posts
Posted 02 July 2013 - 05:06 PM
Thanks for that. I wasn't sure whether it was the CO2 one or the Argon one I needed as it's got both gases in it.
To save starting another topic, I am also buying an auto dimming mask. This is the best one I have found http://www.ebay.co.u...984.m1438.l2649
However, I'm a bit concerned about how cheap it is. I couldn't find any that are more expensive that aren't covered in flames or skull shaped. Does anyone have any experience with this mask or could recommend another?
Edited by HarrysMini, 02 July 2013 - 05:07 PM.
