4 Pot Metro Calipers, What Size Wheel Is Best ?
11 replies to this topic
#1 miniboy94
miniboy94
  • 64 posts
Posted 02 July 2013 - 10:50 PM
hi there i have recently got my hand on a set of metro 4 pot calipers ready to bolt strait onto my mini but im also in the process of buying some new rims but im not sure what size rims i will need to make sure i clear the caliper once bolterd up ? i currently run 6 x 12 revolution rims deep dish.
am i  best of buying 13 inch rims or sticking with my 12 inch rims ?
thanks ben
#2 herdy
herdy
  • 377 posts
  • Local Club: Notts about minis
Posted 02 July 2013 - 10:59 PM
I was running 12s then switched to 13s with mine, the brakes are better with 12 inch, but i wouldn't say by all that much really.. this is just what i've found though.
#3 miniboy94
miniboy94
  • 64 posts
Posted 02 July 2013 - 11:03 PM
hi herdy thank for reply and thats great :) il buy some new 12 inch alloys then i was just worried incase i buy my new wheels but then there to small and i carnt fit them with the calipers on if that makes sence ?
#4 herdy
herdy
  • 377 posts
Posted 02 July 2013 - 11:17 PM
my standard 12 inch wheels fitted over mine just fine. try them with your current wheels first though, no need to spend money if its not needed.
#5 miniboy94
miniboy94
  • 64 posts
Posted 19 July 2013 - 04:59 PM
hi dilligaf and ow right cheers :) and where is the best place to get disc from and pads ?
#6 adamg1380
adamg1380
  • 141 posts
Posted 19 July 2013 - 06:21 PM
Minispares will have what you need, but they're just 8.4" mini disks anyway aren't they? Unless they're metro turbo / vented ones.
#7 krusher74
krusher74
  • 127 posts
Posted 19 July 2013 - 08:05 PM
Bare in mind that Metros had 12 inch wheels.......
with a very large ET, not all 12" wheels may clear.
#8 adamg1380
adamg1380
  • 141 posts
Posted 19 July 2013 - 10:23 PM
What difference would the ET make? clearance would be about the inside diameter of the inside edge of the wheel.
With minspares 4 pots and vented disks (so the same as metro turbo) all the "standard" mini 12" wheels fit fine - minilites, revolutions and 3rd party mini-lite-like wheels. With non-vented 4 pots I'd expect any mini 12" wheel to fit.
#9 rgray
rgray
  • 26 posts
Posted 20 July 2013 - 12:14 AM
will u be selling ur revolutions?
#10 miniboy94
miniboy94
  • 64 posts
Posted 22 September 2013 - 02:06 PM
hi
adamg1380
iv been told there turbo i belive and that i need to run vented disc unless there all the same ? not really to sure iv got everythng i need bar pads, disc and drive flangers as iv been told i need them now to ? any help would be great and yes rgray im selling revolutions deep dish 6 by 12 they are come up really clean with a bit of tlc as they being stood in garge for a while now :)
thanks ben
#11 adamg1380
adamg1380
  • 141 posts
Posted 26 September 2013 - 09:46 PM
If they're metro turbo calipers you will need the drive flanges, and disks and pads, I got it all (plus the alloy calipers) from minispares. So basically everything in this kit apart from the calipers, and the hoses are optional (they are good though): https://www.minispar.../C-AJJ4029.aspx
Even with vented you won't need to worry about wheels I don't think, I've just got standard 12 x 5s on mine.
Edited by adamg1380, 26 September 2013 - 09:48 PM.
#12 adamg1380
adamg1380
  • 141 posts
Posted 26 September 2013 - 09:48 PM
Oh, and there are these as well: https://www.minispar...s/C-GBD496.aspx though they're probably not needed for the road.
