Oil Leak
15 replies to this topic
#1 MrElliott
MrElliott
  • 419 posts
  • Local Club: Box Hill Mini Club
Posted 07 July 2013 - 09:54 PM
Okay so I've been struggling to locate the source of an oil leak coming from my 998cc manual 1990 mini engine.
The leak starts after driving the car for 10 mins once its all warmed up nicely and it seems to be coming out from the front left side of the engine as you look at the engine from the front.
I've changed the oil pipe from block to filter head and the oil pressure sensor that is located in the area of the leak but to no success as the oil just seems to pour out :/
There is a nut looking thing under this which looks fairly solid but is covered in oil... as is the starter motor and my driveway (sorry mum).
my question to you guys is what is this nut looking thing? can I just replace it and hope the leak stops? is it a common leak area?
thanks for any help as its driving me mad :/
Elliott
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 07 July 2013 - 10:02 PM
when you changed the pipe did you use NEW copper washers.......
#3 Gremlin
Gremlin
  • 2,142 posts
Posted 07 July 2013 - 10:48 PM
Or aneal them
#4 MrElliott
MrElliott
  • 419 posts
Posted 07 July 2013 - 10:55 PM
Yep did that :) and the sensor thing was a tapered thread neither of which are now leaking
#5 MrElliott
MrElliott
  • 419 posts
Posted 07 July 2013 - 11:00 PM
But its still leaking from the area below them :/ any ideas on the thing that lookes like a nut/ bolt?
elliott
#6 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 08 July 2013 - 04:42 AM
I guess the thing you mention is oil relief valve bolt. Think that has copper washer as well. Use new one or heat it and reuse. Be careful when undoing, the spring can jump out!
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 08 July 2013 - 05:10 AM
oil pressure valve nut and washer.
replace washer and clean area, test drive and see what happens.
Also worth checking for cracks around the oil pressure sender from over tightening. a small wrap of PTFE tape on the threads wont harm either.
It could also be the oil pressure sender is u/s, oil can pass through them and leak from electrical connector. (typical on vaux corsa)
#8 MrElliott
MrElliott
  • 419 posts
Posted 08 July 2013 - 09:34 AM
thanks guys ill get to it :)
#9 MrElliott
MrElliott
  • 419 posts
Posted 08 July 2013 - 10:11 AM
I just had anther look at it and ive cleaned away some oil to get a better view and I haven't got a clue as to what this thingy under the oil relief valve :/ any ideas?
thanks again
Elliott
#10 mk1leg
mk1leg
  • 9,343 posts
Posted 08 July 2013 - 02:54 PM
thats just an oil gallery bung.....it should not leak from that that done when all the machinning is finished there are a few of those in a blich some you can see others are inside other parts pitted....... :proud:
#11 Yoda
Yoda
  • 1,958 posts
Posted 08 July 2013 - 04:27 PM
It looks suspiciously like a pop rivet to me!
#12 MrElliott
MrElliott
  • 419 posts
Posted 08 July 2013 - 07:04 PM
that's exactly what I first thought :/
#13 lsto
lsto
  • 689 posts
Posted 08 July 2013 - 07:49 PM
Well the bung on my motor looks exactly the same as that, I thought it was someone doing a bodge a few years before I owned it
#14 chrisdeakin
chrisdeakin
  • 151 posts
Posted 08 July 2013 - 08:00 PM
when i asked about oil leak i was told it was on purpose to stop sub frame leaking...
#15 lsto
lsto
  • 689 posts
Posted 08 July 2013 - 08:04 PM
Sub frame leaking?... lol :gimme:
