I have just got a 1966 Morris Mini minor with engine taken out to 1340cc. Im having a bit of trouble with clutch. At normal speeds it engages fine and doesn't slip. But when I drive it fast and and at high rev's, change gear, it takes a short while for the clutch to fully engage. I suspect the clutch is slipping or isnt engaging quickly enough.
Is this the clutch slipping or is it something else.
Also if it is the clutch slipping, and needs a new clutch plate, is it a major job to change?
Thanks in advance.
