Front Panel Differences
6 replies to this topic
#1 BUNYIP
BUNYIP
  • 67 posts
Posted 08 July 2013 - 11:53 AM
i have a 1974 mark 3 and am currently replacing the front end, i purchased a one at a show sunday and was assured it was for models up to 1976, my mate has a 1978 cooper shell hes working on with me, i've had a look and can't see any major differences, can anyone shed a bit of light on the differences? and if it is the wrong panel can i still use it. ( i bought mine with the front end and wings removed so i have nothing to refer to)
#2 pdaykin
pdaykin
  • 587 posts
Posted 08 July 2013 - 12:28 PM
I don't think there is a 78 cooper.
There were lots of detailed changes over the years/models.
I think the main one as far as you are probably concerned will be how the tear drop mounts fit at the front - cant think off-hand what changed in 76 to make the panel only suitable for up to that year.
But provided it isn't for pre 1970 it should be OK
#3 BUNYIP
BUNYIP
  • 67 posts
Posted 08 July 2013 - 12:49 PM
 may be a 1275???? if not a cooper
thanks for the help, do you think i will get away with just buying the tear drop mounts? i have contacted the guy i bought it off and he's pretty sure it was just a rubber bush and washer?
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 08 July 2013 - 09:42 PM
Main differences in saloon front panels is, upto 1964 has full skirt, 1965-1976 has brake cooling cut outs in skirt, then 1976 on is for rubber mounted subframe, then other than this the cooper s has a different stiffener to allow fitment of an oil cooler, but a later front panel can be converted to fit earlier cars if subframe mounting points are changed over.
#5 I've A MINI
I've A MINI
    Just On Tickover
  • 5 posts
Posted 12 July 2013 - 06:01 PM
Hi bunyip sounds like we are on a similar project, I have purchased a front end
for my 1975. I don't think there any many differences, I am down the garage later and ill take some measurements.
#6 I've A MINI
I've A MINI
    Just On Tickover
  • 5 posts
Posted 12 July 2013 - 08:50 PM
Sorry Binyip couldn't get in to measure, the lad was welding(hes better at it than me). Ill try again tomorrow.
#7 I've A MINI
I've A MINI
    Just On Tickover
  • 5 posts
Posted 18 July 2013 - 03:35 PM
Bunyip just been down the garage doing some measurements, if you look straight on at the mini the O/S is 3/4 of a bob bigger and the N/S is 1/2 a bob bigger. if you need any help the measurement I know some one who can help.
