Very quick question.
Mini conked out on the way home a few weeks ago.
Whilst on the side of the road, I checked the usual things as to why it was not firing.
- Strong Spark
- Turning over
- No fuel to cylinders
So yesterday I decided to have a quick look at why there was no fuel.
- disconnected the fuel pump outlet, turned over - fuel present
- disconnected the fuel inlet to the carb, turned over - fuel present
- removed the float from the carb, turned over - fuel present
- put everything back, turned over - fires for a second or two, then dies off
One mate has recommended rebuilding the carb, which I am happy to do, but before setting aside a day this weekend, is there anything else that's worth a look before doing so? (i.e. blasting everything with some carb cleaner?)
Thanks in advance.
