Mini Auto Engine Swop
11 replies to this topic
#1 deakin1988
deakin1988
  • 116 posts
Posted 11 July 2013 - 12:00 PM
Hi all I need some help. Im thinking about taking out my mini 1000cc auto engine and swopping it with a 1300cc auto mg metro engine. Has anyone done it and how hard is it
Thank you
#2 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 11 July 2013 - 03:47 PM
No such thing as an MG Metro Auto, I'm pretty sure they were all manuals!
#3 deakin1988
deakin1988
  • 116 posts
Posted 11 July 2013 - 03:58 PM
No I have seen some metros for sale on ebay that are autos
#4 MMM1965
MMM1965
  • 93 posts
Posted 11 July 2013 - 04:23 PM
There were auto Metro's but never an auto MG Metro
#5 deakin1988
deakin1988
  • 116 posts
Posted 11 July 2013 - 04:59 PM
Ok soz im new to this my mini is my 1st classic. So can anyone help me
Thank you
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 11 July 2013 - 05:05 PM
There was a VDP auto, and the VDP used the same engine codes as the MG Metro.
But regards the OP.... it's almost a straight swap...
What you will need is the selector from the metro as the 1300 auto box has a Park where as the 998 auto does not, you will also need a mini 1275 radiator bracket and top hose as you'll not be able to use the ones from the 998 and obviously the metro unit will not come with the side mounted radiator.
The only other thing is a change to the wiring as the start inhibitor on the 1300 is on the front of the gearbox, and on the 998 it's in the selector.
#7 deakin1988
deakin1988
  • 116 posts
Posted 11 July 2013 - 05:11 PM
Thanks thats has help me alot. It looks like a its all go. Will the 1275 rad keep it cool will long trip.
Thank you
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 11 July 2013 - 05:15 PM
you mean the 998 rad... and yes it will, technically there is not differentiation between a radiator used on a 998 and one used on a 1275...
Obviously you can't use the radiator from the Metro, well you can, but you need to chop a hole in the front of your mini to do so...
#9 deakin1988
deakin1988
  • 116 posts
Posted 11 July 2013 - 06:02 PM
Dont want to chop anything. I like the standard look its just I found it struggling going up hills and just want abit more GO in the car
Thank you
#10 Rob Gavin
Rob Gavin
  • 138 posts
  • Local Club: no
Posted 05 February 2017 - 05:47 PM
bit of a post resurrection here.  I'm just about to change an early 998 auto for a 1275 out of a metro.  Looking at the comment above regarding the metro selector, I assume the original mini cable has to be used with it?
#11 limby2000
limby2000
  • 366 posts
Posted 07 February 2017 - 06:51 PM
The 998 selector does,nt have the park function, you will need one from a mini 1275, you may be able to use the metro,s although this is slightly different and may have a different mounting footprint. Also the metro selector cable is slightly longer.
#12 Rob Gavin
Rob Gavin
  • 138 posts
  • Local Club: no
Posted 08 February 2017 - 10:56 AM
thanks;  I appreciate the selector is different on the later car;  I'll need to strip the metro one out and look but I'm assuming the good old rover parts bin will have kept it similar.  The question was more on if the 998 cable could be used on the later car
