Simple electrics I assumed.12v goes to one of the radiator thermo-switch connections,green and white.The other is black.Connect them together,the relay goes and the fan runs.But if I put a separate 12v supply up that same black wire the relay doesnt energise and too many amps are being drawn (over 10) so I have to stop. How does it work??
Also if I put the thermo-swich in boiling water should it then open and make a circuit?
I want to run a switched 12v supply(toggle switch in the car) to a trigger on the fan relay but if I do that to any of the 4, it doesnt energise.
I dont get it,hopefully some one does.
