Nightmare With Ignition/starter/battery/alternator
Best Answer jonnyfawr , 15 July 2013 - 06:29 PM
Refitted the old ignition relay (the one i thought was shot)...started first time...happy days
on the upside..
1. polished up the horn while i was fitting the new starter motor, so it nice and shiny now.
2. I now know the wiring inside out !!
thanks for all the help
Go to the full post
Posted 13 July 2013 - 07:40 PM
Having so many problems with starting my '89 mini 998.
Started with the battery not charging, so changed the alternator.
She still started like a dog, turning over really slowly, so checked the starter motor, cleaned it up and refitted it(seemed ok).
At this point the ignition light came on ok, but the starter didn't even try to turn...the ignition relay wasn't clicking, so changed that...now I don't even get the ignition light to come on!! Really fed up!
I've checked the volts at the battery, 12.6
Checked the volts at the starter (live cable), 12.5
Volts at alternator 12.5
Checked the four fuses..ok
Checked the 2 in line fuses..ok
What can I check next?
Appreciate any help
Posted 13 July 2013 - 07:45 PM
Posted 13 July 2013 - 08:23 PM
Posted 13 July 2013 - 08:32 PM
Posted 14 July 2013 - 11:25 AM
There almost certainly would be - now check it under load. Switch the lights on and see what voltage you have at the starter if it's pre-enganged compared to the body itself, then compared to the engine.
Headlights aren't a huge load but will be enough to start you off looking for high impedance.
Remember on low voltage - just because you see volts with no load, doesn't mean there isn't a very high resistance somewhere - sounds like that here.
Posted 14 July 2013 - 12:00 PM
Are you sure the battery is not just completely flat now?
Posted 14 July 2013 - 12:56 PM
With headlights and fan blower...12.0
Cleaned up the earth bolt and now have ignition light, ignition relay is clicking, nothing happening at the starter though.
Should i blow £80 on a new starter?
Edited by jonnyfawr, 14 July 2013 - 12:57 PM.
Posted 14 July 2013 - 06:05 PM
As far as I'm aware, you'll still get ~12v from the battery even if it's pretty much flat; It's the fact that there is not enough current left to crank the engine over.
Definately try either charging the battery or jump-starting it off another car. Mine always clicks when the battery is near-enough flat.
Posted 14 July 2013 - 10:51 PM
At the starter, without ignition ...12.5
As suggested, jump it and see what happens.
The alternator also needs a good earth path to charge.
Posted 15 July 2013 - 12:03 PM
fitted new battery earth lead, new starter motor...and nothing, just the relay clicking...what next?
Edited by jonnyfawr, 15 July 2013 - 12:45 PM.
Posted 15 July 2013 - 12:18 PM
Edited by mrbridger, 15 July 2013 - 12:19 PM.
Posted 15 July 2013 - 12:54 PM
I had a 1989 mini with similar symptoms and went through quite a few starter solenoids (small yellow or green relay cubes on the drivers inner wing). They became faulty and just clicked themselves to death! Replacing this should solve your problem.
thanks but ive fitted a new one (the old one stopped clicking altogether) this clicks like mad, but nothing happening at the starter ![]()
Edited by jonnyfawr, 15 July 2013 - 01:32 PM.
Posted 15 July 2013 - 06:29 PM Best Answer
on the upside..
Edited by jonnyfawr, 15 July 2013 - 06:57 PM.
Posted 15 July 2013 - 06:44 PM
Posted 15 July 2013 - 08:22 PM
