I'm about to change both upper and lower balljoints and need to know how to work out how many shims I'll need. How will I know when I've fitted enough? any help will be greatly appreciated.
Ball Joints
Posted 14 July 2013 - 05:30 PM
Posted 14 July 2013 - 05:41 PM
Easier to cut and paste the manual than type it myself:
7 Before final reassembly of the balljoint, it is
necessary to determine the correct number
and size of shims required to provide a snug
fit of the ball-pin with the domed retaining nut
fully tightened. This is done in the following
way.
8 Place the lockwasher in position and refit
the grease nipple. Now place all the available
shims over the lockwasher and then refit the
ball-pin seat, the ball-pin and domed retaining
nut. Assemble all the parts without grease at
this stage, and if working on the lower balljoint
do not fit the ball-pin seat tension spring.
9 Fully tighten the retaining nut and then check
the movement of the ball-pin. With all the
available shims fitted, it should be quite slack
with considerable up-and-down movement.
10 Using a trial and error process, remove
the retaining nut, take out a shim and then
refit the nut and recheck the movement of the
ballpin. Continue doing this until it is possible
to move the ball-pin in all directions, without
binding, but with slight resistance to
movement being felt.
11 Dismantle the joint again, lubricate all the
parts with general purpose grease and finally
reassemble the joint. If working on the lower
assembly, the ball-pin seat tension spring
should now be fitted (see illustrations).
12 Tighten the retaining nut fully, check that
the ball-pin still moves freely with only slight
resistance, and if satisfactory bend up the
lockwasher to secure the retaining nut (see
illustrations).
13 Refit the rubber dust cover to the balljoint
(see illustration) and then refit the swivel hub
as described in Section 3
Posted 14 July 2013 - 07:26 PM
Jesus!!!! Thanks very much. I must admit I was expecting a shorter answer, but thanks for finding the answer for me. Sounds easy enough and I'll give it a go next weekend. Thanks again>
Posted 14 July 2013 - 08:43 PM
You will need to lap the ball joints in. This is best done with some fine grinding paste. Basically this is bedding them in and will also ensure they do not bind.
Have a look at this thread
http://www.theminifo...hat-is-lapping/
Posted 14 July 2013 - 11:10 PM
If you make an error every time they'll never get done haha
Posted 15 July 2013 - 12:16 PM
Ensure that they are not too tight, which is dangerous, as fatigue fracture will occur some time later.
Edit: I assume the quote is from Haynes, which does not contradict that, or disagree with the Rover manual, but I prefer to work to the Rover manual.
The official Rover manual requires between "no nip" and an end float of 3 thou, with another 3 thou shim (the thinnest) to be added if in doubt. The latest version of the manual adds more warnings about not being too tight. I have always set them up in accordance with that, slightly looser than some suggest, and found that they last a very long time if done carefully, but I do aim for well under 3 thou end float, while still moving freely.
Lapping will increase the clearance slightly, but don't use it to make adjustments, just to get a good working surface. If the shimming does not get the clearance close enough, you can increase clearance by taking the ball seat out and lapping the back (flat side) on a carpenter's oil stone, or you can decrease clearance by lapping the flat face of the ball nut (the bit that sits against the shims).
There were a few idiots here who were advocating setting them up tighter, but they have been quiet lately. Perhaps they all crashed due to ball joint failure?
Edited by tiger99, 15 July 2013 - 12:17 PM.
