Needle And Timing Help
6 replies to this topic
#1 Gremlin
Gremlin
  • 2,142 posts
Posted 15 July 2013 - 07:20 AM
I've just put a 12G295 head on my 998 and I have a AAU needle in the 1.5" HS4, we need more petrol throughout the rev range apart from idle, because if we wind the jet down a bit, it runs a lot better but doesn't idle
Also, we did not touch the distributor but it is backfiring ocasionally and running on?
Any help appreciated
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 15 July 2013 - 07:22 AM
Forgot to say we've got a smoothed out ram pipe, carburettor and alloy inlet manifold, lcb manifold - (2" at exit) and 2" straight through system
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 15 July 2013 - 07:53 AM
try AAA or AAM
http://www.mintylamb.co.uk/suneedle/
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 July 2013 - 09:46 AM
The 2inch exhaust on a 998 is going to cost you a bit of power though, to big for a small bore motor
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 15 July 2013 - 12:43 PM
advance the timing to 16 degree's btdc at 1500rpms.........But listen out for any signs of pinking under load and if it pinks knock it back a little.......
Thanks very much, I'll try that, is that with the vac pipe conected or disconnected?
#6 jaydee
jaydee
  • 8,565 posts
Posted 15 July 2013 - 12:50 PM
Vacuum disconnected
#7 Gremlin
Gremlin
  • 2,142 posts
Posted 15 July 2013 - 01:20 PM
Cheers guys, thats what I thought, just confirming
