Co Levels
Posted 15 July 2013 - 04:57 PM
Posted 15 July 2013 - 06:04 PM
What type of mini do you have? Carb or injection? and is it modified like cam and head ?
My 1330 with a stage 4 head and a 276 cam and a Aldon Yellow on a HIF44 under those conditions is about 1%CO
1.0% CO or a 14.1:1 AFR with a Standard / Mild performance engine; or 1.0% - 3.0% CO or a 14.1 – 13.4:1 AFR with high performance cam;
Any less than 1% on Carb engines and you can find it very snatchy on a very light throttle AFR by the way is Air Fuel Ratio which lots of Gauges report in with a Lamba Sensor, they respond quicker than a conventional CO machine.
Edited by KernowCooper, 15 July 2013 - 06:12 PM.
Posted 15 July 2013 - 07:12 PM
What should the CO % be at 3-4000 RPM when I'm cruising along
1.1 to 1.5 CO
Posted 15 July 2013 - 09:23 PM
