Popping On Overrun
17 replies to this topic
#1 Ripple
Ripple
  • 116 posts
Posted 16 July 2013 - 10:56 PM
I had a full stainless system fitted to my 97 MPI recently with decat pipe, since this has been on I get a very heavy pop and crackle anytime I take my foot off the accelerator and let the engine take the strain. I assume this is unburnt fuel getting into the exhaust but I am little concerned about damage to the manifold (as this seems to be where it's burning) and not as much but fuel consumption obviously has to be higher than it should be as I'm burning fuel in the pipework rather the the engine
Any ideas of how to reduce/fix this and how concerned I should be about any damage being caused
Ta in advance guys
#2 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 16 July 2013 - 11:21 PM
Its not blowing is it?
Mine used to pop on overrun when the exhaust blew, but then again, the popping could be due to lack of backpressure (in my case, due to the blowing at the manifold)
As you've fitted a decat maybe you've reduced backpressure and thus the popping.
I might be wrong, but thats my logical spin on things!
#3 6joshh6
6joshh6
  • 224 posts
Posted 17 July 2013 - 12:13 AM
It could be a problem with your exhaust manifold joint; I had a dodgy seal between the two pipes and it made it pop and bang loads so it might be worth going over the manifold (especially the Y piece) and checking for leaks.
#4 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 17 July 2013 - 03:01 PM
I have a 97 mpi mate and I fitted a full decat system too, it pops like crazy but I haven't found any leaks or anything so I have left it...
Edited by Fossy313, 17 July 2013 - 03:01 PM.
#5 Fossy313
Fossy313
  • 583 posts
Posted 17 July 2013 - 03:14 PM
Ripple there is loads on the tinterweb about this, it's a common thing with the mpi and a larger bore exhaust as log as u rule out no leaks, it's just unburnt fuel, it's a common occurrence with minis, mine does it and it seems like loads of other people's have it, it's more common in mpis and with the decat pipe fitted none of the unburnt fuel popping is silenced so it sounds louder........I love mine when it pops haha
Edited by Fossy313, 18 July 2013 - 07:08 AM.
#6 Ripple
Ripple
  • 116 posts
Posted 17 July 2013 - 05:04 PM
thx all...
Fossy, thats just what i wanted to hear, there's no blow anywhere and just wanted to know if any others had the same problems
#7 Fossy313
Fossy313
  • 583 posts
Posted 18 July 2013 - 07:07 AM
Jesus mate sorry I just re read that and the text is awful, stupid predicted text on my phone..
#8 Ripple
Ripple
  • 116 posts
Posted 18 July 2013 - 06:28 PM
Lol... Damn you autocorrect!!!
Could have been worse
http://www.damnyouau...y/best-of-dyac/
#9 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2013 - 06:55 PM
Thats normal and wont damage you manifold.
#10 Minimad100
Minimad100
  • 416 posts
Posted 18 July 2013 - 10:59 PM
My 1999 mpi with LCB and big bore exhaust is the same too!! Wakes you up in the mornings lol
#11 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 18 July 2013 - 11:22 PM
Popping on over ru. Is normally a lean condition iirc. Google it.
#12 Fossy313
Fossy313
  • 583 posts
Posted 19 July 2013 - 07:06 AM
It's normally a lean mixture however you can't do anything to change the mpi s fuel or timing as its controlled by the unchangeable ecu, as long as their are no leas its just a bit of unhurt fuel causing a reaction with oxygen, the decat pipe added to this due to having no cat. Just double check for leaks but most mpi s with a big bore exhaust will pop due to having injectors, being the main reason why carbs don't do it as much.
#13 Fossy313
Fossy313
  • 583 posts
Posted 19 July 2013 - 07:08 AM
Hahaha that made me chuckle!!
#14 minimaxie
minimaxie
  • 1,687 posts
Posted 19 July 2013 - 07:27 AM
I thought that was normal on an MPi? They tend to overun and pop quite a bit, if you're worried, check all the sensors such as the vacuum, idle air control valve, lambdor sensor etc. Check for leaks all over but to me that sounds normal, mine does it very rarely with a standard pea shooter and CAT still fitted lol
#15 Fossy313
Fossy313
  • 583 posts
Posted 20 July 2013 - 06:30 AM
Mine pops like crazy!! But I have got a big bore decated maniflow full system
Edited by Fossy313, 28 July 2013 - 06:28 AM.
