mikuni HSR 45 carb, and spares:
- Conversion plate (will fit a mini pattern)
- Spare needle
- pressure needle a seat( it has a gravity fed needle and seat in at the mo)
- Uprated deep jet nut.
- Two different jet sizes (std and rich)
- Mikuni aux jet for high fuel applications
All parts are Mikuni originals and unused.
The carb has run on my car, and has a modified needle and jet. (you will need to swap these out for the parts above as it will be too rich)
Ok will this fit a mini.... short answer is yes, but you will need to have it setup at a rolling road. So this will be a custom setup. The link below shows it running on a mini and other cars...
http://www.v-perform...s/air_fuel.html
I was going to use this on my Supercharged car, these carb flow very very well, and started to have it setup when we found we needed a pressurised needle and seat sp we could use it with my fuel pump.
I have since been offered a Specailist Components fuel injection setup at a good price so I have taken the plung mid upgrade :) so need to seel some parts to try and make the wife happy, or I will be sleeping in the garage with the car...
£180 +post or collect from chester.
Edited by Gr4h4m, 21 July 2013 - 07:18 PM.
