With the wife due to give birth at the end of the year the Mini may have to make way for a second car a bit more practical.
1977 Clubman Estate
Around 32k miles from new (I have no reason to believe this isn't genuine)
Purchased from a family friend in 2011, it was in their family for at least 25 years, and was garaged since 1996. I've got a whole folder of old receipts, MOTs and photos.
Build thread here: http://www.theminifo...clubman-estate/
I believe that it's 90% original metal. I think the A panels have been replaced, and both sills (not over!) have been patched.
1098cc engine, was dyno'd at 53bhp. 12 months MOT earned in May.
List of work completed:
New silver plastic rear registration plate lights
New Maniflow full length exhaust (bullet silencer)
New mild steel exhaust manifold
New rear window sliders/seals
Rebuilt rear brakes - drums, shoes, springs, cylinders
Floor painted with black hammer paint and drain holes sealed
New carpets
2nd hand vinyl low back buckets
New alloy door furniture
2nd hand 10" steering wheel
MPi dash trimmed in black vinyl
2nd hand voltage gauge fitted
2nd hand oil pressure gauge fitted
Small patch welded on drivers sill
10" steel wheels changed for 10" alloys
Front brakes rebuilt - shoes, springs, cylinders
New braided brake hoses all round
New lucas coil
New 70amp alternator
Engine bits painted matt black
New heater valve
Full service of oil, filter, air filter, spark plugs, ht leads, coolant, thermostat
New inlet manifold
New carb needle
New non-waxstat carb jet
2nd hand 5mm spacers on rear
New wiper arms and blades
New 3 pin hazard/indicator relays
2nd hand Monte Carlo roof rack
2nd hand splash guard
New windscreen washer pump
Brake switch changed to electric
New rubber suspension cones all round
2nd hand hi-los fitted all round
New knuckles all round
2nd hand Gmax shocks all round
New Wipac headlight conversion
2nd hand sump guard
New front subframe rear mounts
2nd hand locking seat belts
Plus a load of other bits I must have forgotten
