What Battery
Posted 21 July 2013 - 08:17 PM
Posted 21 July 2013 - 08:31 PM
Not again, do a search next time. The biggest and best value would be a 075 Pug diesel battery.
Edited by TehMarchant, 21 July 2013 - 08:32 PM.
Posted 21 July 2013 - 08:32 PM
Posted 21 July 2013 - 08:46 PM
075 fits
Halfords list
038 standard
or
053 upgrade
Edited by OfMini&Men, 21 July 2013 - 08:46 PM.
Posted 21 July 2013 - 09:22 PM
halfords 075
3 types to choose from whichever you like
Posted 22 July 2013 - 11:31 PM
075 or 063
Wouldn't bother with the 038, it's only £40 (iirc) at helfrauds, but its only 265 CCA
A standard lead 063, comes in at 360 CCA, if your running a stereo or etc definitely worth the extra grunt
Don't whatever you do buy any cheap lion or banner battery - they are naff! (to say the least)
Can get a decent bosh S3 063 for £40 on the bay!
Posted 23 July 2013 - 09:47 AM
Depends on what alternator you have
dont fit a 60Ah battery if you have a 40ah alternator
theres a varta blue top battery available in 40Ah and 45Ah and those have a CCA of about 430-450
Have a look in FAQ section, Kernow posted something about batteries.
Posted 23 July 2013 - 10:16 AM
Im sure I fitted an 086
Its from a pug 306 diesel.
Perfect fit,
Posted 23 July 2013 - 10:31 AM
Alternator wont make any difference, way it works is if you have a 60a/h battery and a 60 a/h alternator it will in theory charge it in a hour except it wont as when flat the 60a/h alternator will only put in a maximum amount of charge for a sec or two and then the regulator will cut the charge back so a 40a/h alternator will also charge a 60a/h battery or a 300a/h battery for that matter.
When the alternator needs to be bigger is when the total current draw of the whole circuit is 60a/h and you have a 40a/h alternator, then the reserve in the battery is being pulled out to replace the difference on the max charge of the alternator.
And if you think about it you can charge a 60amp hour battery with a 500mw home charger
If the max current draw never exceeds the max output of the alternator then the battery is charged, so even the early 22a Dynamo with a 101 control box can charge a 60a/h battery no problem, but put 4 Cibies on and you in trouble.
Edited by KernowCooper, 23 July 2013 - 10:32 AM.
Posted 23 July 2013 - 10:39 AM
One thing is a home charger, one thing is car, theres a huge risk you wont be able to fully charge the battery if you do short trips and have extra accessory fitted
Posted 23 July 2013 - 10:52 AM
which is the same as a dynamo used to be its the short trips the problem not the dynamo or battery . if you had a 45a/h 17ACR and a 45a/h battery you could still have the problem.
Posted 23 July 2013 - 12:57 PM
Very true, thats why dont reccomend a big Ah battery, most minis are being used as a weekend toy and arent run for more than half hour, best to get a battery with a healty cold cranking amperage.
Otherwise it will just drain power through the alternator and probably the battery will have a short life itself.
My bini neither has a big capacity battery and its got a 105Ah alternator, it simply uses a 55Ah battery with a good CCA (580 iirc).
