Matching Speedo And Revcounter
4 replies to this topic
#1 adamg1380
adamg1380
  • 141 posts
Posted 23 July 2013 - 11:17 AM
I have a matching pair of Speedex 100mm gauges for sale (click for bigger pics):
Attached File  Speedex-Fronts.jpg   48.66K   65 downloads
Attached File  Speedex-Backs.jpg   37.8K   12 downloads
170mph Speedometer, classic mini screw on fitting - works with a mini centre binnacle speedo cable. Approx 1000TPM, so based on things like http://www.guess-wor.../Tech/ratio.htm there should be speedo drives to get pretty close on most minis. Tested and working, no bulb or bulb holder.
8k RVI Revcounter, tested and working. With brand new bulb holder and bulb.
Condition as in the photos, the faces and glass on both are very good, the bezel on the rev counter has been repainted, the bezel on the speedo is showing a few marks.
Both are Stewart Warner gauges branded Speedex. Speedex was the company formed by Jem Marsh, of Marcos fame, in the 50s and 60s - see http://myweb.tiscali...edex/index.htm. Despite the fact that revcounter is an RVI one, the gauges are probably from the period in the 80s when Marcos cars were having a bit of a dip and Jem Marsh revived the Speedex name. The phone number on the gaues matches the one on an 80s catalog: http://www.swissmarc...og_Backsite.pdf and http://www.swissmarc...r_from_Jem.pdf.
NB The speedo TPM is approximate, and comes from comparing the speedo to an uncalibrated mini 1248 TPM speedo. 1000TPM is fairly normal for an aftermarket gauge, and for one of US origin, so it's likely to be right, but it would really want an exact TPM working out for choosing speedo drive gears.
NB The revcounter is *RVI*, NOT the more modern RVC, and as it stands it will work fine with a dizzy and points (I've tested it on mine with and Aldon yellow) but will NOT work with any kind of electronic ignition (and might damage some). RVI gauges can be converted to RVC (diy or there are places that will do it, and refurb the gauge at the same time), or a common mod is to transplant the workings of an RVC revcounter into an RVI body.
Looking for £50 for both.
Edited by adamg1380, 15 August 2013 - 10:21 AM.
#2 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 23 July 2013 - 11:43 AM
You must state a price as per forum rules
#3 adamg1380
adamg1380
  • 141 posts
Posted 23 July 2013 - 12:01 PM
Sorry, you are right, my fault.
Looking for £50 the pair.
#4 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 23 July 2013 - 04:26 PM
No worries :thumbsup:
#5 adamg1380
adamg1380
  • 141 posts
Posted 15 August 2013 - 10:23 AM
Quick bump, I might transplant an RVC revcounter into the body of this one if they don't sell.
