1275 Timing For 23D4 Dizzy
1 reply to this topic
#1 mrloaf
mrloaf
  • 11 posts
  • Local Club: no
Posted 23 July 2013 - 03:00 PM
Hello all,
I don't have a haynes, so I'm asking. What is the timing for a 1275 Cooper with a 23D4 dizzy (no vacuum advance)
and the rpm for setting the timing?
The dizzy was removed and rebuilt & now it runs a bit rough.
thanks
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 July 2013 - 10:28 PM
This is all the information I have listed for your car
Mini Cooper S 1275cc (1964-71)
Engine   Type
  • 12FA (Mk1, 2)
  • 12H (Mk3)
Capacity 1275 cc (77.9 cu. in) Compression ratio (970cc) 9.71:1 Compression ratio (1071cc) 9:1
Firing order 1,3,4,2 Compression Pressure (High) 190 to 200 psi (13.36 to 14.07 kg/cm2)
Idling speed (approx) 600 rpm (approx) Fast idle 1000 rpm
Ignition timing (static) 2 degrees BTDC Ignition timing (600 rpm) 4 degrees BTDC Timing marks Dimples on timing wheels, marks on flywheel.
Valve rocker clearance 0.012 in (0.305mm) cold, 0.015 in (0.38mm) for competition.
Distributor   Type Lucas 23D4 (no vacuum advance) Rotation of rotor Anti-clockwise Dwell 60 +/- 3 degrees
Contact breaker gap 0.014 to 0.016 in (0.35 to 0.4mm) Condenser capacity 0.18 to 0.24 micro-farads
Serial number 40819, 41033
Centrifugal Advance   Decelerating check, vacuum pipe disconnected
  • 28 to 32 degrees at 7000 rpm
  • 22 to 26 degrees at 5200 rpm
  • 10 to 14 degrees at 1600 rpm
  • 6 to 12 degrees at 1000 rpm
  • 0 to 3 degrees at 600 rpm
No advance below 450 rpm
Spark Plugs
Type
Champion Type N9Y Gap 0.025 in (0.625 mm)
Ignition Coil   Type Lucas HA12 Primary resistance at 20 degrees C 3.0 to 3.4 ohms (cold) Current consumption 3.9 amps
Carburettors   Type Twin SU HS2 Piston spring Red Jet size 0.090 in (2.29mm) Needle (standard) M Needle (rich) AH2 Needle (weak) EB
Edited by KernowCooper, 23 July 2013 - 10:31 PM.
