Hi All,
I am new to the forum (well new to posting a question anyway)...
I have a problem with my mini not starting and really need some help.
firstly a bit of background....
I have 2 minis, a 1993 italian job, and a 1979 1275 GT
The GT was a runner (replacment engine from 1990) but needs alot of work, so really is at the start of a resto job.
1993 mini is a 1275, HIF38, electronic ignition, stage 1 kit, ( I have also fitted remote central locking, its very cool, but thats another story )
I got the 1993 mini on the road last year, and my wife has been using it every day since.
Starts first time every time..
was last used on friday last week, Monday morning this week, would not start, and also could smell petrol.
Monday evening I took a look, and could not get it to start. but couldn't see any leaks.
I have tested for a spark, thats fine. (out of desperation tried the distributor from GT engine, same electronic type) still would not start. (at this point I have to assume all timings are good)
also, after each time trying to start, took out plugs and nitice how wet with fuel they were)
then i suspected fuel in the oil, thinking it could be a fault in the carb, I swapped it for a HIF44 (again from the GT engine)
this time i got it to start once, but was making a loud screaming sound (which I am now thinking is because of the lack of oil in the bore because of the petrol seeping down) then it cut out and would not start again,
Tonight I have drained the oil, and sure enough, loads of fuel in the oil (somewhere between 1/4 and 1/2 tank since filled up friday)
I also took out the plugs, and while thinking what to do next, fuel started overflowing out of no 2 spark plug hole.
Does anyone have any ideas what could cause the fuel to syphon into the cylinders in that way?
what stops fuel flow while the car is not running?
anyway, if you have got this far, thanks for reading and I hope someone can help.
