Help! Advice Seeked... Drive Belt
6 replies to this topic
#1 SNOWDEN1974
SNOWDEN1974
  • 24 posts
Posted 26 July 2013 - 06:55 PM
 Hi guys, need some urgent advise... car has been parked up now for flipping months, had a mare of a day... just picked up 3rd battery of the day!!
and it started... and shredded the drive belt... now to the question... i have to get this car to a mechanic tomorrow to do soem body and suspension work...
Can i drive it without the drivebelt??? its probably a 30 minute drive... and from what i can make out.. the drive belt runs the water pump... now as far as i am concerned... no water pump, no water... no water = engine bang!!!
i am 100% thinking that its not driveable until the belt is replaced... but need the advise and help of soemeone who does no what there doing!!!
#2 sledgehammer
sledgehammer
  • 3,109 posts
Posted 26 July 2013 - 06:57 PM
no - do not  drive
check the water pump pulley moves smoothly & the alternator the same
check pulley's are in line with each other
belts usually  slip / squeal - unless it was old - but you usually get a warning before snapping / shredding
I would hope a mini fan belt is still easy to get
best of  luck
Edited by sledgehammer, 26 July 2013 - 07:01 PM.
#3 SNOWDEN1974
SNOWDEN1974
  • 24 posts
Posted 26 July 2013 - 07:00 PM
blinding thx... going to have to get it recovered - just didn't want to do untold damage.  Thanks very much for your help.  Much appreciated.
#4 sledgehammer
sledgehammer
  • 3,109 posts
Posted 26 July 2013 - 07:07 PM
No probs -
try to get a belt - cheaper than recovery
#5 SNOWDEN1974
SNOWDEN1974
  • 24 posts
Posted 26 July 2013 - 07:13 PM
yeh tell me about it... only problem being fly on hols for two weeks tomorrow night and its taken me forever to find a garage semi local that can work on a mini... everyone other garage doesn't seem to no what there doing unless they can plug it into a computer!!
stress just before hols.. not needed... bottle of red now. and feet up!! while i swear repeatedly!! thx though... just need to be told kind of what i already knew.. which is very little  :proud:
#6 Ethel
  • 26,166 posts
Posted 26 July 2013 - 09:38 PM
You could probably manage 3 or 4 miles with no belt if you took it steady. Any garage ought to be up to fitting a fan belt. even Halfords. Though you could do it yourself in half an hour with just 2 or 3 spanners.
#7 sledgehammer
sledgehammer
  • 3,109 posts
Posted 27 July 2013 - 01:04 PM
problem is , he lives in Watford according to sig - Id give it a mile in that location before it boils in this weather
