Engine Takes Longer To Start Mpi
8 replies to this topic
#1 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 27 July 2013 - 09:24 AM
Hi guys, over te past week or so I have recognised my mini needing more and more cranks to start, noticeable enough for me to post on here, this morning coming to work it caught then almost died but I pumped the throttle to keep it going,
Only noticeable things I have done recently is mod the airbox and do a full oil change and filter to commas 20w 50 classic engine oil.... Any ideas? When I got to work I switched it off and started it and it was taking a good 3-4 seconds to start before it jumped into life....am I just worrying? .... I have had so much go wrong with the car I am just waiting for something else so might just be me.
#2 nev_payne
nev_payne
  • 2,249 posts
Posted 27 July 2013 - 12:52 PM
Good sparks on the plugs? Does the fuel pump kick in with a distinct pressurising sound before you crank the engine?
#3 Fossy313
Fossy313
  • 583 posts
Posted 27 July 2013 - 03:46 PM
Haven't checked the sparks, how's best to do that? And yer fuel pump makes the whine and that when u turn the key to stage 2
#4 jamesmpi
jamesmpi
  • 1,940 posts
Posted 27 July 2013 - 04:05 PM
New battery time. Get a Bosch silver battery. Halford a do them. I can't say exactly which one you need (don't want you to buy the wrong one) but I have one on my mpi and it starts first time.
#5 Fossy313
Fossy313
  • 583 posts
Posted 27 July 2013 - 04:16 PM
Think it might be, cheers mate u reakon it's just battery?
#6 jamesmpi
jamesmpi
  • 1,940 posts
Posted 27 July 2013 - 04:41 PM
That's where I would start. How old is your battery? Do you use your car daily or does it stay parked up for a while connected up?
Batteries are renowned for draining on mpis and once they fall to 10v they are knackered.
You could try charging it up and see if that makes a difference.
Edited by jamesmpi, 27 July 2013 - 04:41 PM.
#7 Fossy313
Fossy313
  • 583 posts
Posted 27 July 2013 - 06:48 PM
Yer I may do, only charged it up last week tho.... The battery isn't that old but didnt know they drain on MPIs, the battery is however a top up with distiller water one
#8 Island Mini
Island Mini
  • 448 posts
  • Local Club: Wish there was one
Posted 28 July 2013 - 04:42 PM
Check and clean your lambda sensor or take the head off and clean/decoke the valves. I used to have to crank my engine for 20 secs until it spluttered into life now it starts straight off.
#9 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 29 July 2013 - 10:42 AM
check your earths
