Hi folks I have a 1293 running on road/rally cam, 4:1 FD, Aldon Yellow dizzy, lightened flywheel, duplex chains, Mainflow exhaust system (LCB/RC40) and a reworked original S head. I currently have HS2 1 1/4" twins with K & N on them with M needles and red springs. I also have a set of 1 1/2" which have been rebuilt on an osselli manifold. I would like some opions on what the thoughts are on 1 1/4" or 1 1/2" would there be any benefit. The car is to remain period so I don't want to fit 1 3/4" single. I know the works 1275s had 1 1/2" twins. If there is benefit I will swap but if not I will leave things as they are. Thanks
Hs2 Or Hs4?
Posted 27 July 2013 - 04:07 PM
Posted 27 July 2013 - 06:42 PM
looking at your spec on the engine twin HS2s may well be at there limit especially if there on a standard manifold which were not that good, I always thought 80-85bhp+ was HS2s and anything above HS4s.
Posted 27 July 2013 - 08:58 PM
Thanks Dave my decision made 1 1/2" it is
Posted 27 July 2013 - 09:07 PM
Definitely the HS4's for that spec.
Posted 27 July 2013 - 10:15 PM
Yes - even on a standard 1275 the 1.25" carbs are well beyond their limit..... The 1.5" carbs on a GOOD manifold will make a huge difference.
Posted 28 July 2013 - 04:13 PM
Thanks everyone, do you think an M needle on red springs would be a good start for rolling road, I know the works 1275 SU's used MME but not sure if these are available.
Posted 28 July 2013 - 06:43 PM
Here is some information I have if its of any use.
Edited by KernowCooper, 28 July 2013 - 06:46 PM.
