ive removed my head and 2 out of 4 are leaking so im going to re-seat them
while im doing this should i renew or do anything else while its off???
Posted 29 July 2013 - 07:31 PM
Posted 29 July 2013 - 07:32 PM
Is there play in the valve guides?? replace the valve guide seals.
Valve stem oil seals
Have valve guides checked
Consider a little bit of porting maybe?
Posted 29 July 2013 - 07:33 PM
Great minds think alike ??
Probably worth doing the stem seals why you are at it.
You too
+1Is there play in the valve guides?? replace the valve guide seals.
Posted 29 July 2013 - 07:34 PM
+1
It's that slow Ipad you're using!
To the OP, you could also consider compression ratio calculations
Posted 29 July 2013 - 07:36 PM
Nah, its my damn blackberry, sat waiting for a Pizza at DominosIt's that slow Ipad you're using!+1Is there play in the valve guides?? replace the valve guide seals.
Posted 29 July 2013 - 07:41 PM
I've just sent my MPi head off for a refurb, recut valves, bead blast and a skim, £65 cash.
Posted 29 July 2013 - 07:43 PM
head has built by morspeed its a stage 3 booster head, but the valve guide were reamed wrong
after having this problem sorted the valves weren't re=seated so this is the point im at so its had new valve guides is it still worth doing the seals
Posted 29 July 2013 - 07:45 PM
Posted 29 July 2013 - 07:46 PM
would be £100 ish with postage
Posted 29 July 2013 - 07:47 PM
Always worth doing new seals.
