3 clock dials
14 replies to this topic
#1 Roo
Roo
    The Queen Of The Curly Wurly
  • 3,656 posts
Posted 08 May 2006 - 08:32 PM
Hi
I've just purchased a set of three clock dials to upgrade from the the 2 currently in my mini. They've come from a mini gt. Will they still work with my equinox and if so what will i need to do to connect them? Willl they plug straight in? or will i have to wire the tacho in? if so where would i start?
I would pull my dash off and have a look at what wiring is available, but my mini is still in the garage in kent and I was just looking for some advise for when i get her back and fit them.
Roo
#2 pikey7
pikey7
  • 3,824 posts
Posted 08 May 2006 - 08:40 PM
I'm guessing a bit here, but certianly my '88 had the wiring in place, so I would "assume" that yours would too.
#3 Sam
Sam
    Wish i was in T.O.W.I.E
  • 2,323 posts
Posted 08 May 2006 - 09:51 PM
But Roo's Mini is injection..
.. just to complicate things :thumbsup:
#4 minimole
minimole
  • 781 posts
Posted 08 May 2006 - 10:20 PM
I think the gt clocks are smiths and the injection minis clocks a nippon/nixon something like that anyway. manufactor names arent the point the point is that the 2 are not interchangable
#5 Roo
Roo
  • 3,656 posts
Posted 08 May 2006 - 11:07 PM
So does that mean i can't use them? :thumbsup:
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 08 May 2006 - 11:20 PM
yes
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2006 - 06:37 AM
Apart from the wiring issues, you will also have to change the speedo cable, and probably the pinion drive in the gearbox to get the speedo to read correctly.
#8 Roo
Roo
  • 3,656 posts
Posted 09 May 2006 - 05:17 PM
ok thanks for the help guys.
So if i can't use these dials how will i be able to get a tacho installed? buy one seperatly? if so what do you recommend? or look for a set of dials on ebay for an injection type mini?
Roo
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 May 2006 - 05:25 PM
get a set of dials from a sportpack mini..
#10 Sprocket
Sprocket
  • 7,266 posts
Posted 09 May 2006 - 05:36 PM
Ive heard that the tacho on the MPI reads differently due to the ignition system being wasted spark. Dont know if its true but there is a possability.
Best bet is to find a Nippon set up to 1996
Oh and when you get the Nippon 3 clock set you can swap over your original speedo/oddometer and keep the milege correct
#11 1984mini25
1984mini25
  • 8,785 posts
Posted 09 May 2006 - 06:47 PM
Roo, if they are the the smiths 3 clocks I might have them off you so I can replace my rev counter thats stoped working.
#12 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 09 May 2006 - 08:13 PM
Roo...
I ahve a set of later type 3 clocks... only thing is the Rev counter has come away from the plastic backing...
If u need them, you can have them if ur going to Bristol Mini day!
#13 Roo
Roo
  • 3,656 posts
Posted 10 May 2006 - 11:11 AM
yeah they are smiths clocks. you can have them if ya want 1985mini25.
The clocks would be great Dogmatix but i'm unable to go to bristol mini day due to having to work. I will be going to dragwars. not sure if i'm going to any shows before then. i will be extremly lucky if i go to l2B as my mini is still a wreck from the accident in feb.
Roo
#14 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
Posted 10 May 2006 - 05:10 PM
I am looking into going to DW.
So if I go, you can have them! :errr:
#15 Roo
Roo
  • 3,656 posts
Posted 10 May 2006 - 11:42 PM
Many thanks Dogmatix.
