Electronic Ignition Update
15 replies to this topic
#1 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 July 2013 - 04:41 PM
After Paul Coleman on here Sussed the problem with the electronic ignition trigger wheels, I sorted mine in five minutes. Last week a mate fitted one to his midget, guess what? Nothing at all. This afternoon I took round my combined rotor arm and trigger wheel and it fired up straight away.
It seems that the trigger wheel supplied with the kits does not work. If you fit one of these kits and have a problem, this would be worth checking before you pull your hair out (as I nearly did). The combined rotor/ trigger costs a fiver.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 July 2013 - 05:09 PM
I would tell the supplier of the ignition system if I was you, maybe you have?
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 30 July 2013 - 05:21 PM
I'd like an update on the one that was stopping the engine turning over....
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 July 2013 - 05:26 PM
Yes where it was like to far advanced when cranking, I'll PM the OP
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 30 July 2013 - 05:35 PM
I have emailed them again, I did contact them before but got no reply. Its an easy fix for them, they just need to include the combined rotor arm in the kit and job done.
#6 robminibcy
robminibcy
  • 1,516 posts
Posted 30 July 2013 - 05:39 PM
Which ignition kit was it?.
#7 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Accuspark, but powerspark kits have reportedly had the same problem
#8 robminibcy
robminibcy
  • 1,516 posts
Posted 30 July 2013 - 05:41 PM
I guess its a batch issue? I've got an accuspark kit (6month old now) and its running fine with the trigger ring and a normal rotor arm.
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 July 2013 - 05:42 PM
The Freak was the guy who had problems cranking with the module in but started ok on points, I have sent a PM to ask for a update but hes not been on since the 4th July 2013
Edited by KernowCooper, 30 July 2013 - 05:42 PM.
#10 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 30 July 2013 - 06:21 PM
Quite possibly, the fact that two suppliers have had the same problem would suggest they are getting them from the same wholesaler and then branding them.
Slightly off topic, I noticed when I went on the accuspark website that they have a new programmable module. Any one tried it?
#11 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 30 July 2013 - 06:58 PM
what was the problem?? did the engine not fire up or running weird or rough?? i only ask as i'v got the powerspark kit and its not quite running right and has a bit of a problem with the rain...which is the reason i fitted the kit in the first place!!
#12 Ethel
  • 25,954 posts
Posted 30 July 2013 - 07:18 PM
Nope,
It looks ok, but there's no load input, so it can't be considered a competitor for the likes of Megajolt, Nodiz...
#13 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 30 July 2013 - 07:24 PM
No, nothing at all. Mine and my mates would just not run at all. I think Paul Colemans was the same. With the new rotor/trigger it fired up instantly and runs perfect, the same on my mates. We swapped back to his trigger wheel and nothing again.
#14 TopGearRules
TopGearRules
  • 421 posts
Posted 30 July 2013 - 08:08 PM
I've had my powerspark electronic ignition system fitted for about 5 months now and I've got a similar issue of slow cranking when trying to start the car (always had this problem since I got it). I assume this is a know issue, if so should I contact powerspark and see if they can solve the issue? Al
#15 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 July 2013 - 08:30 PM
They don't know what the problem is being caused by as a cars been in with the fault and were waiting for a outcome from the freak who went to powersparks
